07 Camry Hybrid "VSC" light on power lost to brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2013, 06:21 PM   #1 (permalink)
View dpree's Photo Gallery
I currently own a 07 Toyota Camry Hybrid & the check "VSC" light came on and I lost power to my brakes. What does the light have to do with the power to brakes?
dpree is offline   Reply With Quote
Old 02-18-2013, 12:05 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $1000137450
Hello, welcome to Toyota Nation! I'll move your thread over to the appropriate Camry forum so the members there can help you out. However, VSC lights issues have in all probability been covered many times in the past. You'll want to use that forum's search feature to locate past threads, and especially check through the sticky thread section.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 02-18-2013, 12:58 PM   #3 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1210300
View arabianobsession's Photo Gallery
Hmmmm, that's weird. I turn my VSC off every day in winter time and to be honest I haven't noticed any difference in braking.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1990 Ford Mustang Convertible---1985 AMC Eagle
1990 Honda CBR600F
arabianobsession is offline   Reply With Quote
Old 02-18-2013, 08:01 PM   #4 (permalink)
Gameroom cash: $280215
View Frodo65's Photo Gallery
First step is to pull codes. The TCH uses a unique setup for the brakes - kind of like the ABS pump - which seems to more troublesome than usual Toyota practice. Symptom there is frequent cycling - and that's bad news, as a new replacement is a $1700 part.
With other stuff, wheel sensors are a common fault - but it could be a number of other things, some quite spendy. In any case, pull the codes, and that will guide you to the right area...
Frodo65 is offline   Reply With Quote
