05 Camry SE Owners.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2004, 01:34 AM   #1 (permalink)
View Camdaddy's Photo Gallery
I just got my hands on a 2005 Camry SE 5speed Auto...just wondering if anyone here as a 05 Camry or Camry SE also, I have noticed that when I have the heat on the air compressor comes on as if I had the AC on...Is that normal...someone told me that it was supposed to do that since there is a cabin filtration system...? true??
thanks, Kevin
" The Replacement for Displacement is Technology. "
Camdaddy is offline   Reply With Quote
Old 11-19-2004, 05:22 AM   #2 (permalink)
View 04sev6camry's Photo Gallery
i dont think it should unless u have the heat and u have the ac button pressed in too, but even then your not gonna get any cold air if u have the heat turned way up. if u have the green light for ac on while running the heater, turn it off and see what happens, if not then take it to the dealership cause if your compressor is running your burning up extra gas and horses and u might have something wrong with the compressor or some wireing somewhere
04sev6camry is offline   Reply With Quote
Old 11-19-2004, 10:04 AM   #3 (permalink)
thats what I am thinking, why would the air compressor be coming on when the heat is on...I would call them today and ask them about it..
Old 11-19-2004, 11:29 AM   #4 (permalink)
View FrCrakr77's Photo Gallery
Cabin filtration and compressor operation are unrelated.
The compressor runs--or should run--during heating in order to de-humidify the air, for the purposes of clearing the windscreen and side windows in wet or humid times, and most importantly while the vehicle is cold right after startup -- the heater air temperature is insufficient to vaporize the surface condensation on the glass.
I don't recall if the A/C switch on our cars is overriden in these situations, but it is common on some domestics to have no dedicated A/C switch. The mode selector governs when the compressor runs -- in A/C, Max A/C, or 'Defrost' modes, for example.
Perhaps you could clarify for us if the compressor runs when you have the A/C switch off? If it doesn't, then you have control over it, and can deactivate it on dry days once you've defrosted.
B. Riley
Melbourne, FL
'01 Camry LE V6 5-spd
(was: '00 SVT Contour, #560)
'01 Highlander V6 2WD
FrCrakr77 is offline   Reply With Quote
Old 11-19-2004, 12:04 PM   #5 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
all this considering your not talking about when its set to defog the front windows, then its supposed to turn on as you mentioned. If its set just to dash vents and this prob persists, then you've got a problem.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 11-19-2004, 02:55 PM   #6 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
yes yes.......the A/C on with temp gauge turned to heat= dehumidfied air= you can breathe and won't feel sticky.
Green Light= On
-Custom 2.5 Exhaust + Weapon R Dragon Intake + TRD Rear Sway Bar
-Big 3 + Grounding Kit + TRD Springs
Super Kaioken is offline   Reply With Quote
Old 11-20-2004, 01:11 AM   #7 (permalink)
thanks guys, I called toyota today and asked and thats exactly what they said, but on mines. When on the defrost modes the A/C button doesn't light up but the air compressor comes on to dehumidify...I have to call them now to see if the light is or isn;t suppose to come on....
