2003 Camry *sloshing* noice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2004, 11:18 AM   #1 (permalink)
Mighty Flying Family Sedn
View Mighty~Mart's Photo Gallery
ocassionaly i hear a noise from the engine while i'm accelerating.... sounds like water being poured into a cup.
anyone know what this is?
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Mighty~Mart is offline   Reply With Quote
Old 12-10-2004, 12:14 PM   #2 (permalink)
LR6
View LR6's Photo Gallery
Same Here!
I have an '02 Camry with the 4 cyl and 34K Miles and I am having the same problem. For me it happens when accelerating or braking and goes away after a little while
LR6 is offline   Reply With Quote
Old 12-10-2004, 12:35 PM   #3 (permalink)
View AdamS's Photo Gallery
Generally this is a symptom of air in the cooling system. Some cars have a bleeder screw for the cooling system to allow air to escape. In general, you run the car with the screw open, and the heater running on low (so that the heater core is circulating fluid).
If there is no screw sometimes a hand vacuum pump (Mityvac, etc) that takes the place of the radiator cap (this is a Mityvac accessory) can allow you to remove air from the system.
If you are under warranty (which you ought to be) take it to the dealer, they should be able to easily remedy the problem.
-Adam
AdamS is offline   Reply With Quote
