2001 626 vs 2005 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2005, 07:58 PM   #1 (permalink)
View witxp's Photo Gallery
Hi, on my 01 626 4cyl going 65mph requires close to 3000rpm, but my 05 camry 4cyl was hovering around or under 2000. I though only V6 engines do that.
Is this due to their vvti engine? or something is wrong with my camry?
also the camry feels like it's going slow even when the tech says 60.
Thanks
witxp is offline   Reply With Quote
Old 04-19-2005, 08:03 PM   #2 (permalink)
5spd V6 ClrTail's Avatar
View 5spd V6 ClrTail's Photo Gallery
first of all your camry is light years ahead of the 626. New Camry's have a 5th overdrive automatic gear. People want high speed and low RPM. That means your car eats less gas and has a much higher top speed. The car feels slower at 60 mph is because it requires less effort than a 626. The Camry's gearing and aerodynamics is practically driving itself.
5spd V6 ClrTail is offline   Reply With Quote
Old 04-19-2005, 08:30 PM   #3 (permalink)
View warlock's Photo Gallery
2 different cars and makes. take a porch and a camry and you will see the same thing but porchas are made with more power. and run better at higher rpms.
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 04-19-2005, 08:40 PM   #4 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
Thanks
probably just the gear ratio is different between the two cars, doesn't have to be vvti
if the vehicle is well made and solid, good noise insulation, you won't feel the speed,
on the other hand, if you have leaky windy noise from windows, and rattling inscrease portional to speed, then psychologically, you ears exagerate the speed to your brain
bronzemaxell is offline   Reply With Quote
Old 04-19-2005, 09:09 PM   #5 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
are you just making that up?
mescalito is offline   Reply With Quote
Old 04-19-2005, 09:35 PM   #6 (permalink)
yeah, those are from my personal experience,
i have both a lexus and camry,
my lexus going at 60mph slow and quiet
my gen3 camry going at same speed with rattle and more vibration feels traveling at higher speed.
