gen 5 camry power window failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2005, 12:09 PM   #1 (permalink)
View ribeater's Photo Gallery
I'm wondering if anyone else has had this problem or if this is a known problem area for the gen 5 camry. My rear driver side power window motor failed just after I bought the car.
ribeater is offline   Reply With Quote
Old 08-19-2005, 12:26 PM   #2 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
i don't know what year your gen5 is, but that should def. be a dealer fix issue - take it back to them and see what is up, i have not heard of this being a common problem
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 08-19-2005, 01:12 PM   #3 (permalink)
View foompla's Photo Gallery
the regualtor bolts work their way loose and sometimes cut the harness.
foompla is offline   Reply With Quote
Old 08-19-2005, 01:37 PM   #4 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
could be a fuse? i dunno
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 08-19-2005, 01:50 PM   #5 (permalink)
id take apart the panel and check to make sure all the bolts are tight.
Old 08-19-2005, 02:36 PM   #6 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Hey mine also failed right when i got my camry. I took the door panel off and checked that the motor was getting power and it is but the problem was inside the motor; the little carbon teeth that give the electricity to the inside of the motor are just worn out, so i looked to see if i could replace the motor but it turns out that i have to replace the whole thing that lifts up the whole window. I still havent replace mine and i plan on going to pick and pull this weekend to see if the have any camrys.
V6LE_CAMRY is offline   Reply With Quote
Old 08-19-2005, 03:55 PM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Man. i would just take it to the dealership
should be still under warranty...
skewe is offline   Reply With Quote
Old 08-19-2005, 04:15 PM   #8 (permalink)
View CamryEvolution's Photo Gallery
I drive a 2002 Gen5, and the rear driver side power window failed around 25k miles, and when i took it to the dealership, they replaced the wire or harness, forgot exactly what they did. But about 2 months ago it failed on me again, since it was around 40k miles, past warranties, i took it to a shop that my dad knew, and i ended up having to replace the motor. Even since i havent had any problems with the power windows, and i better not have that problem again since the motor was replaced.
CamryEvolution is offline   Reply With Quote
Old 08-19-2005, 07:19 PM   #9 (permalink)
It's a 2002 and the bumper to bumper warranty has expired. The dealership already looked at it and quoted me $520 for a new motor. Since it was a Certified Pre-Owned just purchased in June I put in a complaint with Toyota Canada. They will get back to me in about a week but I imagine they will say the same thing as the dealership...tough luck.
Old 10-05-2005, 10:12 AM   #10 (permalink)
View AirJose's Photo Gallery
Gen5
I have the same problem on my 2002, Gen 5. The left rear (behind driver) power window will not work, check all the fuses and all are ok. Car has 59k and the rear windows are rarely used. Out of warranty. Will it be a common problem?
AirJose is offline   Reply With Quote
Old 10-05-2005, 03:25 PM   #11 (permalink)
The Cool Guy
same here......the door behind the driver's child safety lock doesn't work correctly.
The door is stuck on child lock and WILL NOT UNLOCK! plus the button stays orange even though i press the power lock button. but the door's locked =/
Old 10-05-2005, 06:21 PM   #12 (permalink)
View articledon's Photo Gallery
damn. I thought these things should work for years without problems. what do you docontinously roll up and down your windows?
$520.00 for a motor? I suggest if you have any techincal abilities to do it your self. order the motor. I doubt it is more than 200$
2003 LE 20% tint all around
Future plans: 18" rims, foglights,new stereo system
articledon is offline   Reply With Quote
Old 10-05-2005, 09:22 PM   #13 (permalink)
View brazilgoal's Photo Gallery
I just replaced my driver's side rear window motor last week. At 34K it was still under warranty. It works fine now. Dealer was very kind, diagnosed the problem and fix ed it with no questions. They also fixed a lot of wind noise and squeeks.
Camry SE '03 2.4L Gen. 5 - Black
Manual Transmission
K&N air filter
Grounding system - Homemade
Enkei Wheels 16 in. 5-spoke alum
brazilgoal is offline   Reply With Quote
