Gen 5 Camry clear corner How to's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2002, 01:04 PM   #1 (permalink)
Jaspher's Avatar
View Jaspher's Photo Gallery
Can any please post on how to remove the orange reflector off the Gen 5 camry headlight.
Thanks Guys!!! :P
2012 Rav4 4WD Touring Package with heated leather seats
2006 Corolla CE-C w/ leather seats and 17" TRD wheels
Jaspher is offline   Reply With Quote
Old 10-17-2002, 09:05 PM   #2 (permalink)
View Fartmander's Photo Gallery
I tried doing it, but you have to break the seal of the front headlight and then you have to use something to seal it back up. The problem is moisture might leak in after you take it apart. That's why I didn't do it.
Fartmander is offline   Reply With Quote
Old 10-17-2002, 09:11 PM   #3 (permalink)
Jaspher, where did you get your supertoned horns?
Old 10-17-2002, 09:48 PM   #4 (permalink)
Jaspher's Avatar
I was thinking for removing the amber reflector by un-sealing the whole headlight housing but I didn't want the moisture as well.
Regarding the Hella Supertones I got them from the Philippines, but I'm sure you can get it here from North America. Are you from Toronto?
Old 10-18-2002, 12:41 PM   #5 (permalink)
I'm from Cali. how much do the horns usually run for?
Old 10-18-2002, 01:31 PM   #6 (permalink)
Jaspher's Avatar
Around $80CDN but i've seen it on some website for $50USD.
just do a search on your search engine for "hella supertone horns" and it should lead you to sites that sells them.
Old 08-01-2004, 02:55 PM   #7 (permalink)
View SoCal_CJ's Photo Gallery
you can get these all over the place,
85115 - Hella Supertone Horn Kit, Long range. Two horns, mounting brackets and relay. Horns are metal disc type. One 300 Hz and one 500Hz. 144 Watts.118db at 6'. Best for freeway use as sound pattern is narrow and projected forward. Picture.
$65.00
85315 - Hella Supertone Horn Kit, Long range. Two horns, mounting brackets and relay. Horns are metal disc type. One 300 Hz and one 375Hz. 113db at 6'. Best for freeway use as sound pattern is narrow and projected forward. Picture.
$43.10
I like this vendor….
http://catalog.com/susq/hella/misc.htm
none
SoCal_CJ is offline   Reply With Quote
