Changing / Flushing Transmission Fluid in 2003 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 13 Old 05-01-2006, 08:35 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA Changing / Flushing Transmission Fluid in 2003 Camry
Hello,
I've got a 2003 Camry that I need to change the and/or flush the transmission fluid in. I know the fluid is a bit burnt but it doesn't look too bad!
Someone told me that I just need to drop the pan, let it drain, replace gasket and pan and refill. Is that accurate, and complete?
Thanks,
:b!
BDMcGrew is offline
post #2 of 13 Old 05-01-2006, 12:39 PM
Quoted: 0 Post(s)
Dropping the pan will only replace a couple quarts out of the 8 quarts or so that are in the system. If you do enough drain and refills you will eventually change out all of the fluid. Personally, I just do a flush every couple years and have had no problems.
patrick5 is offline
post #3 of 13 Old 05-01-2006, 04:30 PM
Prepare tortilla chips.
Daffunda's Avatar
Quoted: 1 Post(s)
The trans fluid does not need to be changed. I explained this earlier a while back, but the technology for software and hardware is sufficient enough nowadays so that the trans does not need a new fluid every 30k miles.
But you could change it if you want to. Dropping the pan is the best way. This way, you can get all the gunk and fine particles out of the system. FLUSHING on the other hand, can be dangerous, since it can work so well it can get all the gunk into the V/B, screwing everything up.
So if you want to drop the pan and change it, no harm done. FLUSHING at the oil change station, not good.
Daffunda is offline
post #4 of 13 Old 06-10-2006, 04:03 PM
Senior TN Member
Quoted: 2 Post(s)
Change the fluid, it is easy to do
Its even easier than that, IMO no need to drop the pan. Its got a strainer that doesnt get changed but cleaned, and unless the fluid is really dirty i'd just leave it be. Your car isnt all that old, and that strainer can hold a lot before it really needs cleaning. If you were to drop the pan i think you'll probly find the strainer to still be clean.
It's easier than changing the oil - just remove the drain plug with a 10mm hex and drain it. And then refill with about 3.5 qts of whatever your owners manual says it uses. It might require Toyota TIV fluid so i d check that. Hint, its easier to know how much to put back if you measure how much came out.
Regarding the fluid never needing to be changed...I've always changed the fluid in my auto transmission equipped cars. And i've never had a trans problem nor replaced an auto trans, even on cars with closeto 200,000 miles.
marc780 is offline
post #5 of 13 Old 06-10-2006, 04:57 PM
Quoted: 85 Post(s)
I agree with Marc. Drain and refill it every 30,000 miles using the supplied 10MM allen head drain bolt. It's cheap insurance and it's no more difficult than an oil change. You might need a long neck funnel to make the job easier when refilling through the the dipstick hole. When you check the owner's manual for the correct type of trans fluid, also check it for the quantity of fluid required for a drain and refill. The trans for the generation 3 and 4 4 cylinder 5SFE engines only takes 2.6 quarts for a drain and refill.
Mike
Mike Gerber is offline
post #6 of 13 Old 06-15-2006, 02:27 AM
Quoted: 0 Post(s)
Another drain and refil vote.
I have three Toyotas.
They all get a drain and refill in the spring and fall.
One has 84k and one has 75k with no problems with the transmissions.
RichR is offline
post #7 of 13 Old 06-15-2006, 07:49 AM
02
JMSinMD's Avatar
Quoted: 197 Post(s)
Suggestion
I flush every 30,000 miles. I figure for $130 why not? That's about every 3 years for me. Jon
JMSinMD is offline
post #8 of 13 Old 07-30-2006, 03:37 PM
Banned
Digger1's Avatar
Quoted: 0 Post(s)
Thumbs up
I'm w/ Marc and Mike, except I change the fluid every 20K miles and clean the filter out every 60K miles. I've never seen a dirty filter on my Toyotas, even when one had over 190K miles on it.
I used to change the fluid every 30K miles, but my Gen 1 tranny started burning fluid at about 180K miles, so I decreased the interval to every 20K miles on my Gen 4 when I got it(see signature). Changing tranny fluid is easy, cheap insurance.
Digger1 is offline
post #9 of 13 Old 11-10-2012, 02:28 PM
Quoted: 0 Post(s)
Hi, since u guys are talking about a 2003 LE Camry I decided to join. I just bought that exact model about 2 months ago and I've felt great with it. It has no problem at all, great engine, drives smoothly and everything. A couple of days ago I took it on its first long trip to New Orleans.
I dont know anything about its maintenance, but I do know that Toyotas dont give much problems. How do I know when I have to change the steering oil or the transmission fluid?
What about the refrigerant? I saw it has like a blue liquid in there... Should I buy these refrigrerants or should I use just water?
What other kind of stuff should I be aware of maintenance-wise?
Humbertodeoz is offline
post #10 of 13 Old 11-10-2012, 02:45 PM
johnfrisco's Avatar
Quoted: 56 Post(s)
Originally Posted by BDMcGrew View Post
Hello,
Thanks,
:b!
So did you drain and fill or flush your fluid?
johnfrisco is offline
post #11 of 13 Old 11-10-2012, 03:14 PM
Senior TN Member
Quoted: 2 Post(s)
What about the refrigerant? I saw it has like a blue liquid in there... Should I buy these refrigerants or should I use just water?
Start by reading the owners manual from cover to cover. And, then find threads with recommendations of maintenance instead of a 6 year old thread from a single poster. Here's a 3 page read: http://www.toyotanation.com/forum/10...gen-camry.html
deadrx7conv is offline
post #12 of 13 Old 11-14-2012, 05:31 AM
Quoted: 0 Post(s)
We have a 2004 Camry with right at 320k miles. 2.4L engine. I have changed the fluid every 30k since we bought it new. Runs like new, no problems no leaks. Pull the plug,drain,refill. I did pull the pan at 200k just to see about any debri, etc, it was spotless.
Central Alabama
2004 Camry XLE 2.4l, 320k 1 owner miles fall 2012, zero problems.
2005 Vibe 1.8l, 196k
mkc1962 is offline
post #13 of 13 Old 11-15-2012, 03:00 PM
Quoted: 21 Post(s)
I have done drain & fill on mine (02 camry) as well every 40K or so. At 118 K now, no issues.
sundarpn is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
Back
