Do Springs go bad when riding on blown struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 15 Old 08-06-2008, 07:23 PM Thread Starter
05_se_lunarmist's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Gen5 Do Springs go bad when riding on blown struts?
I have been dealing with suspension problems for a while... TRD Springs and stock Struts. Fronts make popping noises during slow turns (IE:pullingout of parking spot) and the backs creek and squeel when going over speedbumps. I took the car in to the dealer and they say the struts are blown due to the drop. I have been still driving like this for a couple months and want to know when I replace the struts do I need to replace the springs too or are they Ok? Last thing I want is to pay all tha labor to replace struts and find out next month I need to pay them again to replace the springs too.
So, Are the springs still OK, or should I do a complete replacement?
And what exactly do I need to replace struts? Strut itself, Mount, boot, gaskets, seals..? I have no idea. Tire rack sells the strut and the boot and the mount. Do I neet to buy all of them?
2005 Camry SE V6
TRD Springs, TRD RSB, 18x7.5 Wheels, 225/45/18 Tires
05_se_lunarmist is offline
post #2 of 15 Old 08-06-2008, 07:57 PM
"Circle of trust"
Quoted: 2 Post(s)
Springs do not need to be replaced. Look for a set of after-market struts/shocks that you like and is within your price range. Good luck!
Eric.
catric69 is offline
post #3 of 15 Old 08-06-2008, 08:01 PM
Quoted: 1 Post(s)
Do your struts have leaking oil all over them?
If not, they are probably ok.
njerald is offline
post #4 of 15 Old 08-07-2008, 01:27 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I haven't checked personally but I have major creeking and noise coming from the rears that I never had before. Is it a mount, strut, or spring issue?
Also, I talked with a shop yesterday and the guy told me the poping sound is common and won't go away so long as the car is lowered. I would like to take a poll of how many of you guys have your camry lowered and have sound issues from the suspension and how many of you have lowering springs and have no sound issues from the suspension...
2005 Camry SE V6
post #5 of 15 Old 08-07-2008, 09:49 AM
Nostalgia Member
Venom_5's Avatar
Quoted: 1 Post(s)
popping is common, but can often be corrected - it can be caused by a spring that is not properly seated (which is what happens to me), or can be from a bad strut mount, suspension bushings, etc.
when lowering a car with springs, you should always upgrade to better struts that are made for lowering springs - stock struts are 100x more likely to blow
R.I.P. '95 Camry LE
"Blurple" '96 240SX SE <Weekend Car>
'95 Acura Integra GSR - Sold
2013 Scion FR-S <New DD>
Venom_5 is offline
post #6 of 15 Old 08-07-2008, 10:23 AM
Joined the dark side. :D
workerant's Avatar
Quoted: 839 Post(s)
So to correctly lowering the car... how much r u looking at to spend to do it correctly? $1k? $2k?
I just want to know.. I know I won't lower it.
workerant is offline
post #7 of 15 Old 08-07-2008, 10:24 AM
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
Quoted: 3 Post(s)
Your drop did not cause the strut failure. When the vehicle is dropped the struts will travel less and actually last longer in many cases. It seems that people are under the impression that the pressure inside the struts increase when you drop the car. That isn't true.
TRD spring noise is common. Do a search. You can clean and lube the spring contact points which helps to relieve some of the binding noises you hear as the spring moves.
I'm having a hard time believing that you need struts and/or strut mounts on an '05.
2006 Camry LE Special Edition
TRD VVTi is offline
post #8 of 15 Old 08-07-2008, 01:03 PM
Sedan Life
CharmCityES's Avatar
Quoted: 2 Post(s)
your springs are fine im sure....the only way ive seen springs go bad on a toyota is from cracking and rusting out due to extreme age
im dropped on TRD springs on a 63k mile 2003 camry and my struts are nice and blown....im upgrading to KYB GR2's as soon as i get them in the mail and well see how that goes....ive had some suspension issues with my car for the past month or so (instability, pulling, lack of dampening force, bottoming out, etc) but no noise...the noise is usually associated with the strut mounts going bad
i scored the KYBs off ebay...grab a set off there as theyre reasonable, and get oem strut mounts...itll save you a little money and theyre better struts for your springs!
"I'm the dude, man."
CharmCityES is offline
post #9 of 15 Old 08-07-2008, 06:27 PM
Senior TN Member
johnnyzee's Avatar
Quoted: 0 Post(s)
i'm dropped on eibachs and never heard a pop ever (2-3yrs drpped)
johnnyzee is offline
post #10 of 15 Old 08-07-2008, 11:48 PM
Senior TN Member
Quoted: 1 Post(s)
i do have poping noise when turning slowly but i grease it up like trd vvti suggesgted and can barely hear the noise any more,
a bit off topic but is KYB Gr2 strut better then stock Se strut??? and what might be the price different between them
LoudCamry is offline
post #11 of 15 Old 08-09-2008, 09:44 AM
Senior TN Member
johnnyzee's Avatar
Quoted: 0 Post(s)
^ slightly better, ever so slightly.
post #12 of 15 Old 08-09-2008, 02:55 PM
Sedan Life
Quoted: 2 Post(s)
i got my KYB GR2's from a seller off ebay called sparkplugsource....theyre the 2002-2003 struts only, but i got them for 302 shipped to my door
post #13 of 15 Old 08-09-2008, 10:39 PM
Senior TN Member
Quoted: 1 Post(s)
^^^ can you please do a little review, comparing the kyb and the stock se strut. i think my strut is about to go bad, it making a werid noise now and the rubber thingy is stuck to it, also when the strut are blown, doe the leak seem a tack sticky???
post #14 of 15 Old 08-09-2008, 11:25 PM
Sedan Life
Quoted: 2 Post(s)
haha doe the leak seem a tack sticky?
yes the struts will leak a sticky oil that will run down the housing of the strut if theyre blown
my struts are not dampening at all, and the car always feels like its loose and bouncing around....in addition, the car likes to wander and such at speed
the struts do make a popping noise at low speed turns as well
ill also be sure and post a small review of the new struts
post #15 of 15 Old 08-11-2008, 02:56 AM
Senior TN Member
Quoted: 1 Post(s)
i think my driver side strut is blown or somthing, it make a werid noise and the rubber thingy is stuck, i have pics of it, also the red/pinky thingy on the spring is grease, before my spring make lots of noise but aftter super greasing it the noise wear down and stop.
right side strut
driver side
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
Back
