PO402 Cat efficiency code?? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 13 Old 02-11-2011, 08:38 AM Thread Starter
Panhead Jim's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Gen5 PO402 Cat efficiency code??
2002 Camry 4 cyl. Clear the codes, drive the car 6 or 8 drive cycles, then the light comes back and throws the code PO402. Computer says this is cat efficiency issue. If anybody has a list of the possible culprits for this code, I sure would appreciate it. BTW - 2 cans Seafoam in full tank of fuel yesterday. I read somewhere that somebody had had success with it on PO402 in 4th Gen. Prolly EGR code for 4th Gen, though...
Thank you bunches.
Jim
Panhead Jim
2002 Camry LE 4-cyl
Panhead Jim is offline
post #2 of 13 Old 02-11-2011, 09:53 AM
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Quoted: 4 Post(s)
iTrader Score: 13 reviews
I tried looking that up for you, but in the FSM I only come up with that code on the 6 cyl, not the 4.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline
post #3 of 13 Old 02-11-2011, 10:43 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Do you mean the cat efficiency definition by the computer or the PO402 in general? My concern with the light coming on - staying on is that until I can resolve, I run the risk of not knowing when some other "checkengine" issue arises. Thank you for your help!
Jim
Panhead Jim
2002 Camry LE 4-cyl
post #4 of 13 Old 02-11-2011, 11:20 AM
Quoted: 4 Post(s)
The P0402.
When I was looking up that code, all the information pertaining to the P0402 code was for a 6 cyl.
Jim
678-854-9601
post #5 of 13 Old 02-11-2011, 11:23 AM
Quoted: 0 Post(s)
The only cat system efficiency system below threshold is P0420 (not P0402). I have had it on my 4runner goes on once awhile but it turns off. I have experienced with it for over a year now.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline
post #6 of 13 Old 02-11-2011, 11:52 AM
Quoted: 4 Post(s)
If it is a P0420, I do have information on that.
678-854-9601
post #7 of 13 Old 02-11-2011, 02:14 PM
Quoted: 0 Post(s)
Please list the information.
post #8 of 13 Old 02-11-2011, 02:32 PM
Quoted: 4 Post(s)
Did you need information on your 4Runner?
678-854-9601
post #9 of 13 Old 02-11-2011, 06:25 PM
Somewhat a Lurker
Quoted: 0 Post(s)
Agent556 is offline
post #10 of 13 Old 02-11-2011, 08:07 PM
イリジウム
Quoted: 254 Post(s)
Is the engine well tuned? How are the spark plugs? Valve clearances/stem seals may need to be checked/replaced?
If new sensors don't fix this problem then it's the catalytic converter, especially if you confirm it with a smog check.
Under an old TSB some covered vehicles had ECM reprogrammed and a new catalytic converter installed.
Thank you bunches.
Jim
JohnGD is offline
post #11 of 13 Old 02-11-2011, 08:16 PM
Quoted: 0 Post(s)
no for the op. I have techstream
post #12 of 13 Old 02-15-2011, 11:25 AM
2004 Camry LE
somick's Avatar
Quoted: 35 Post(s)
That what I found in my archives. I hope it will help you:
P0420
TSB No. EG013-04
Quote: “Some 2002 - 2004 model year Camry vehicles equipped with the 4 cylinder (2AZ-FE) engine may exhibit a M.l.L. ON" condition with Diagnostic Trouble Code (DTC) P0420 (Catalyst System Efficiency Below Threshold, Bank 1) in the Engine Control Module (ECM) (SAE term: Powertrain Control Module/PCM). The ECM (PCM) logic has been modified and a redesigned catalyst has been provided.
NOTE :The repair procedure in this TSB is similar to TSB No. EG013-04 "Excessive Sulfur Dioxide Odor." The recalibration of the ECM (PCM) should only be performed ONCE.”
Good luck,
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline
post #13 of 13 Old 02-15-2011, 12:50 PM
Quoted: 1 Post(s)
By and large the P0402 code can be a number of things related to the emissions system (and a few things completely unrelated). I'd first check all your vacuum lines and make sure you have no cracks or rotted connections. Make sure the seal around your gas cap is in good shape (though it often throws a P0400 I think, or P0402, I can't recall). Being that it's bank 1, that means the issue is in front of your catalytic converter (the O2 sensor in bank 1 is giving an unexpected reading).
Beyond those things, a faulty or clogged EGR valve (or purge sensor/solenoid) is most likely the cause. You can often take the EGR Valve off and give it a thorough cleaning (with chlorinated carb/brake cleaner and a wire brush), add a new gasket and you should be set. If the issue is the purge solenoid, I don't know of any way to remedy it, beyond replacing it.
Just as an aside, on some domestic vehicles (GM products in particular), I've seen the coolant temp sensor (SU108, most commonly) be the cause of a number of emission DTCs. I can't explain why, but they happen. On Toyota, though, I'm not entirely sure. Verify that your temperature gauge is reading accurately and radiator fans are kicking on to rule it out, though.
This isn't specific to your particular vehicle (though, being an 02 makes it even more likely), but in my experience that's often been the cause across the board of different makes and models.
NegativeTen is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
Back
