Replacing rear sway bar links - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 8 Old 06-13-2011, 07:06 PM Thread Starter
2007 Camry SE V6
Quoted: 0 Post(s)
(Thread Starter)
I talked to some friends about a clunking noise I'm getting in the rear end of my car when going over certain bumps (not all) and they think I need to replace the rear sway bar links. They said it is somewhat common that when you use aftermarket sway bars, they will wear out the factory links more quickly.
The local Toyota dealership has them for $98 each but I found some Deeza brand links for $35 for the pair.
Any suggestions on where I can find factory replacements cheaper? Also, does this seem like a reasonable next step to take to try and solve this problem?
Thanks!
2007 Camry V6 SE, Blue Ribbon Metallic, UR Strut/Sway Bar, Magnaflow mufflers, H&R Springs, TSW Nurburgring 18x8, Reus Sound System, More
SOLD!!
thrawnis is offline
post #2 of 8 Old 06-13-2011, 10:01 PM
Quoted: 2 Post(s)
my end links began to clunk not long ago too... crawl underneath with a 14mm wrench/ratchet and tighten it, if it comes back in a week take the nut out and run some loc-tite on there then reinstall
Dave-o is offline
post #3 of 8 Old 06-14-2011, 01:30 AM
05_se_lunarmist's Avatar
Quoted: 0 Post(s)
My gen 5.5 TRD rear sway bar made creeking noised over bumps and driveways after about a year from install. I first thought it was the rear struts and/or springs. Turns out the grease got dirty and the bushings needed to be re lubricated and retightened up. That fixed the sounds. Im just now starting to hear them again about 2 years later.
2005 Camry SE V6
TRD Springs, TRD RSB, 18x7.5 Wheels, 225/45/18 Tires
05_se_lunarmist is offline
post #4 of 8 Old 06-14-2011, 10:48 AM Thread Starter
2007 Camry SE V6
Quoted: 0 Post(s)
(Thread Starter)
I just re-lubed the sway bar bracket bushings in hopes that it would help with the clunking noise. Some of the noise went away but most of it is still there.
Re-tightening the links sounds like the next best thing to try before buying new ones. Thanks for the suggestions!
SOLD!!
thrawnis is offline
post #5 of 8 Old 06-14-2011, 12:49 PM
Senior TN Member
Quoted: 226 Post(s)
If you do need new links, buy Deezas, I just got a pair myself. According to a couple tn'ers they are great quality and the boot is double layered so they are less prone to ripping and letting grease out.
pmesfun is offline
post #6 of 8 Old 06-14-2011, 08:16 PM
Quoted: 2 Post(s)
that's cause either your driver's side or passenger side sway bar link is loose!!
Dave-o is offline
post #7 of 8 Old 06-15-2011, 10:45 AM Thread Starter
2007 Camry SE V6
Quoted: 0 Post(s)
(Thread Starter)
I checked both the links and both sides were torqued down to the factory specs. Just to see what would happen, I slightly over-tightened them with no difference in sound.
The next step is to buy the Deeza links and see how they work out. If anyone is interested, the part number is LE-L645 for both the driver and passenger sides. I will let everyone know if this solves the problem once I get the parts installed but it will be a couple weeks before I can install them.
SOLD!!
thrawnis is offline
post #8 of 8 Old 06-16-2011, 12:43 PM
Quoted: 1 Post(s)
Remove the endlinks and move the bolts with one finger. If it freely moves then the bearing is bad and you'll need to replace the endlink. If it's hard to move then it's fine. The endlinks aren't hard to replace. I wouldn't waist money paying someone else to install them if I were you.
It's good to go fast, but even better to be able to stop!!
2007 V6 Camry SE: TRD Air Filter, Power Slot Rotors, Hawk PC pads, Techna-Fit Braided Steel Brake Lines
ImJustMe55 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
ę Back
