Flex pipe replacement for Camry 2002 LE 2.4L - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 18 Old 01-31-2012, 12:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I went for oil change yesterday, and was told the flex pipe (the mesh woven) was leaking due to corrosion. Firestone quoted me $860 to replace the whole pipe with the cat converter and O2 sensor. I was wondering if anyone knows any exhaust shops near Philadelphia can replace the flex pipe only, which needs to be cut off and weld on with the replacement. Thanks in advance
seabreeze is offline
post #2 of 18 Old 01-31-2012, 12:24 PM
Quoted: 1 Post(s)
I wouldn't let Firestone near any car of mine. Finding a flex joint that will fit can be done but you need to know the size,material and application. Find an independent shop with a good welder to install the piece. Regards
Donald E. George is offline
post #3 of 18 Old 01-31-2012, 12:46 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I was told that I could order the flex pipe online and have it welded on by any welding services. Has anyone done that before? and what's the size of flex pipe?
post #4 of 18 Old 01-31-2012, 01:18 PM
^__^
alexorozco92's Avatar
Quoted: 0 Post(s)
Bro, I'm actually debating a new flex pipe as well.
Mine got torn up going over speed bumps, in/out of driveways and just from daily driving.
Anyone have any thoughts on replacing the flex pipe with just piping?
I know in a months of diving my flex pipe will be torn again.
Low'N Slow
08 Camry: http://www.toyotanation.com/forum/showthread.php?t=386218 08 G37: Ksport Coilovers, Varrstoen ES 2.2.2 19x9.5/10.5 +12, SPC Camber Kit
alexorozco92 is offline
post #5 of 18 Old 01-31-2012, 01:30 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
could not find my original post, why?
post #6 of 18 Old 01-31-2012, 06:26 PM
johnfrisco's Avatar
Quoted: 56 Post(s)
Why does Toyota make these pipes so low to the ground?
johnfrisco is offline
post #7 of 18 Old 01-31-2012, 06:39 PM
Senior TN Member
leakyseals's Avatar
Quoted: 9 Post(s)
I just realized why last month. I had a real bitch of a time replacing the "gas tank heat shield" that rusted and fell on the exhaust. What is that? Because we (02-04) have a full sized spare the tank is farther forward. The exhaust pipe goes right under the tank! move that pipe up, your putting the hot exhaust closer to the bottom of the tank! One drip of gas from a leaky gas tank on that exhaust pipe on a 100 F day.. kaaa-boom!
02 Camry XLE 2AZ-FE 332k M1 HM 5w30
99 Avalon 95k PP 5w30
13 Malibu 16k PP 5w20
leakyseals is offline
post #8 of 18 Old 02-13-2012, 06:21 PM
Quoted: 2 Post(s)
I am in the same boat too. Went for an alignment at sears and the guy said the flex pipe is leaking(he said it is a common problem for camry). The car does make different sound as if something is leaking so need to be replaced soon.
I did get quote in the north of $800.
Can I just buy online(link below), and install it myself? Or am i missing something which I am not aware?
What is NON-CARD compliant anyway.
http://www.amazon.com/Magnaflow-27303-Catalytic-Converter-compliant/dp/B001DRNM4K/ref=au_pf_ss_5?ie=UTF8&Model=Camry%7C1011&n=15684181&s=automotive&Make=Toyota%7C76&Year=2005%7C2005&carId=001
Thanks
grshome is offline
post #9 of 18 Old 02-14-2012, 07:42 PM
07 Camry I4
kaashifv's Avatar
Quoted: 17 Post(s)
I also went to the dealer for service one time and was told the flex pipe needed to be replaced...when i looked at it, it looked almost new! So i had my import mechanic do a pressure test and it checked out fine...$24 for the test, money well spent as it saved me the $900 Toyota wanted!
So be sure to get a second opinion!
kaashifv is offline
post #10 of 18 Old 02-15-2012, 11:35 AM
Quoted: 1 Post(s)
Question
What is the procedure for determining the condition of the flex joint? did the mechanic pressurize that segment of the exhaust system and look for leak down? Regards
post #11 of 18 Old 02-15-2012, 11:58 AM
07 Camry I4
kaashifv's Avatar
Quoted: 17 Post(s)
Yea so basically with the car running he put a gauge on the exhaust and first verified that the pressure was normal then checked the seals to check there was no leaks from the joints around the flex pipe
kaashifv is offline
post #12 of 18 Old 02-15-2012, 12:01 PM
Senior TN Member
carsrus's Avatar
Quoted: 171 Post(s)
Stick a rag over the exhaust and plug it. If you hear hissing/ leaks your exhaust is bad at some point.
You can also just run the car and feel around for leaks around the flex joint. The exhaust is really hot so be careful.
In order for it to leak it'll be visibly torn/ rotted out.
carsrus is offline
post #13 of 18 Old 03-08-2012, 06:20 PM
Quoted: 0 Post(s)
My Toyota dealer also informed me of a leaky exhaust on my 2002 Camry and wanted over $1200(!!) to replace the entire system, since, according to him, they don't do repairs of the exhaust.
I then took my car to the local Midas shop and they replaced the flex pipe (it rusted through) for $200 by cutting out the old and welding on a new stainless steel pipe.
It was a routine job, according to Midas. Obviously, my experience doesn't speak well for the dealer.
weran43 is offline
The Following User Says Thank You to weran43 For This Useful Post:
leakyseals (03-08-2012)
post #14 of 18 Old 03-20-2012, 05:52 PM
Quoted: 0 Post(s)
Go to a Mom and Pop Muffler Shop
just replacing the flex portion of the flex pipe should cost you 100 or less. Any mom and pop muffler place will have tons of these just lying around. I went to change mine and I was trying to explain what I needed changing without knowing its actually name and saw one out of the corner of my eye... I was like how much to put this on my car? So yea.... don't replace all that just the flex arm.... with 800+ you could get a cold air intake+cat back exhaust+flex arm fix.....
Hopefully you did not already get raped
awbrey50 is offline
post #15 of 18 Old 04-30-2013, 09:54 PM
Quoted: 0 Post(s)
use this as an excuse to buy my own MIG?
My '03 Camry's flex tube is toast, and my friend's '02 Camry's flex tube is shot too. Do I have a valid argument to shop for MIG welding equipment? Or do I just take it up the tailpipe and drop my wad at the local muffler shop?
ridetri is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
Back
