Timing Belt Replacement @128k? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 8 Old 03-02-2012, 12:20 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Gen6 Timing Belt Replacement @128k?
Hey folks,
I have a 2007 2.4 L 4-cylinder Camry and have browsed (& searched) the forums and have also read through the owner’s manual. I see that some are posting that at 90K to 100K miles the timing belt should be replaced. Is this a recommendation or is this the actual life that the dealer gives the timing belt? The dealer also recommends an oil change at 3k miles but we all know that's not necessary. My car is in great condition and the only maintenance on the car has been the standard brakes and oil changes, and so forth.
I have checked the timing belt and it still looks good, no cracks, no frays, and is tight. So the question is what is the actual mileage that the timing belt should be replaced and if so should I replace anything else while that's being done, i.e. water pump, spark plugs, etc., as I do not want catastrophic failure on my car...
Any help is appreciated.
stgg44 is offline
post #2 of 8 Old 03-02-2012, 12:26 PM
Quoted: 1 Post(s)
I think you are looking at the accessory drive belt that powers the alternator,AC compressor, power steering pump and waterpump. I believe your engine has a timing chain. Regards
Donald E. George is offline
post #3 of 8 Old 03-02-2012, 12:38 PM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 1607 Post(s)
Your car does not have a timing belt it has a timing chain.
Like stated above the belt you are talking about is the accessory drive belt. This should only be replaced if it is cracked, frayed, or squealing. If it is not any of those leave it alone.
These Camrys are known for going through water pumps by if yours is not leaking I would leave it alone.
You are definitely due for spark plugs. I recommend the factory Denso Plugs you can buy online or at the dealer.
The only other maintenance I recommend is changing your engine coolant (due at 100k), changing transmission fluid (use only Toyota WS fluid), and switch to synthetic oil if you have not already (0W20 Mobil 1 and a good quality oil filter like Purolator, Bosch, or Mobil 1).
My Toyota List:
1982 Corolla SR-5 1JZGTE M/T
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is online now
The Following User Says Thank You to hardtopte72 For This Useful Post:
joe0900 (08-14-2013)
post #4 of 8 Old 03-02-2012, 03:21 PM
Senior TN Member
leakyseals's Avatar
Quoted: 9 Post(s)
I'm at 200k, havent changed anything. You have a chain, the manual has both 4 and 6cyl maintenance, 6 has the belt (think it still does). There is an external serpentine belt, that could crack, I havent changed that either. I spray the tire shine on it. Not sure if thats good or bad but the belt seems to like it.
02 Camry XLE 2AZ-FE 332k M1 HM 5w30
99 Avalon 95k PP 5w30
13 Malibu 16k PP 5w20
leakyseals is offline
post #5 of 8 Old 03-02-2012, 05:43 PM
Quoted: 1 Post(s)
All of the Toyota v6s I have looked at the last few years look like they have a timing chain.Regards
post #6 of 8 Old 03-03-2012, 07:27 AM
Toyota Fanatic
Toyota completely stopped using timing belts in Camrys in 2007.
They finally killed the timing belt in 2010 when the 1URFE replaced the 1UZFE.
Since 2006 the Camry, Solara, Highlander, and Tundra/Sequoia were the only vehicles with Timing Belts.
As for you OP. Do everything I said in the previous post and you will be golden.
My Toyota List:
post #7 of 8 Old 03-03-2012, 02:31 PM
Need For Speed
arabianobsession's Avatar
Quoted: 1 Post(s)
^Not quite. The Highlander Hybrid still had a 3MZ hybrid engine up until 2010, which is a timing belt. The 2011 and newer Highlander Hybrids have the 2GR hybrid engine.
For the 2007 Camry, this is what Toyota recommends for maintenance (normal use):
5,000 miles: Oil change and tire rotation
30,000 miles: Cabin air filter and engine air filter replacement
100,000 miles: Coolant flush (then every 50,000 miles thereafter)
120,000 miles: Spark plugs
Keep in mind that Toyota has no recommendation for changing the power steering fluid, brake fluid, or transmission fluid, but it's a good idea to change those when needed, along with a serpentine belt now and again. All Camrys from 2007 and up use a timing chain, the last year Camry to use a timing belt was 2006, and that was for the V6 engine only. The 4 cylinder Camry hasn't had a timing belt since the 4th generation still had the 5S-FE engine.
6 speed manual 2011 Camry SE
1995 Mustang-1994 Mustang GT
1985 AMC Eagle
arabianobsession is offline
post #8 of 8 Old 03-03-2012, 02:44 PM
Toyota Fanatic
True. I thought they switched that in 2010 as well.
My Toyota List:
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
Tags
2007 camry , maintenance , timing belt
User Tag List
Linear Mode Linear Mode
« Back
