Correct Tire size for Lowered Camry! - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 09-27-2012, 03:48 PM Thread Starter
I'll Beat your Porsche!
2011SECAMRY's Avatar
Quoted: 5 Post(s)
(Thread Starter)
Hey guys! I am looking to go with 18x8 +38 offset with a 245/45/18 tire. The car is lowered approx 2 inches. Before I go and order everything I want to make sure this will fit. I also like the 45 sidewall as it will along with the 18 inch rim raise the front end of my car just a little.. But need to make sure this setup will fit??
P.S. posted this in the sticky but received no response..
Sent from my Autoguide iPhone app
2011 Camry SE V6 Loaded
K&N Intake || Tein Suspension || 6000K HID Headlights ||
3000K HID Foglight's || 20% Tint || UR Strut Bar || UR Rear 23MM Sway Bar || StopTech Drilled Rotors || Hawk Pads ||
Owning it at the track! See Below:
http://youtu.be/1Vm6PNearEU?hd=1&t=1m30s
2011SECAMRY is offline
post #2 of 6 Old 09-27-2012, 05:53 PM
Quoted: 0 Post(s)
Are you running the tein solara springs? If you are a 245/45/18 would rub. You could run a 245/35/18 and maybe just shave your rear fender. I'm on tein Camry springs and runn 19x8.5 +38 offset with a 245/35/19 all around and no issues. I used to run in the rear with passengers on the car before I shaved the fender but since I did that I've never rubbed again. Maybe someone else can chime in and see what there thoughts are.
camry2011 is offline
post #3 of 6 Old 09-27-2012, 06:24 PM
Will
Quoted: 14 Post(s)
iTrader Score: 7 reviews
heres a good link to check iam sure if you have tein solara u will rub if you have ppl
http://www.willtheyfit.com/
willt is offline
post #4 of 6 Old 09-27-2012, 09:51 PM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
Yes Tein Solora springs.. So will a 245/40/18 fit? Also will it look good with that small of a sidewall?
post #5 of 6 Old 09-28-2012, 12:34 AM
270hp = Happy Foot
Quoted: 0 Post(s)
just remember buy going 1 series lower your MPH gauge will be off.
2011 Camry SE V6 Fully Loaded w/o Navi
BC Racing Coilovers with custom 7/4kg Springs
23mm UR Racing RSB
18x8.5in Candy Red Work Emotion CR Kai's
aznlunatic206 is offline
post #6 of 6 Old 09-28-2012, 01:17 PM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
After lots of measuring I am almost positive a 245/45/18 on a 18x8 +38 offset lowered on Tein Solora Springs.. Will fit!
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
Back
