2002 Camry Using Oil - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 12-10-2012, 09:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello,
I have a 2002 Camry with 302,245 miles. I am noticing that it is using a lot of oil. Maybe 2 quarts extra in between oil changes.
I came home tonight and noticed oil on the garage floor. At first I thought it was water from the AC but it smelled and felt like oil.
Could the engine be burning oil and a possible leak?
Thanks!
Kellebell66 is offline
post #2 of 5 Old 12-10-2012, 11:39 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 3716 Post(s)
Hello there, welcome to Toyota Nation! I'll move your thread over to the Camry forums where the other owners there can help you out. I'd also recommend, though, using that forum's search tool to locate past threads regarding oil leaks as that's a fairly common issue.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline
post #3 of 5 Old 12-11-2012, 01:44 AM
Quoted: 1 Post(s)
2 qts over how many miles per oil change? I have 240K miles and I add roughly 1/2 qt every 8K mile oil change. I did replace my valve stem seals and that reduced my oil consumption considerably. I was adding roughly a qt every 8k mile oil change before hand. Also, I have noticed that I use more oil with highway driving versus city driving. For the oil leak, you might want to verify that your oil filter has been properly tightened firts...
FireLikeIYA is offline
post #4 of 5 Old 12-11-2012, 07:19 AM
Senior TN Member
Quoted: 5 Post(s)
Originally Posted by Kellebell66 View Post
Hello,
Thanks!
What engine are we talking about in your 2002 Camry? 2.4L 4-cylinder 2AZ-FE? 3.0L V6 1MZ-FE?
Without knowing the maintenance history, given the mileage, it is very possible the engine is both burning oil & leaking oil. Leaks can originate from anyplace, like valve cover gaskets, camshaft seals, crankshaft seals, oil pump seals, etc. If you had a timing belt change recently, and if you did all the normal front-engine work at the same time, you should have handled many of the leak points. Also, when was the last time you changed the PCV valve? The PCV, if not fuctioning, can cause the crankcase to overpressurize, which assists in pushing oil past weak seals.
93celicaconv is offline
post #5 of 5 Old 12-11-2012, 07:26 AM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 1607 Post(s)
2002 is a 2AZFE 2.4 Timing Chain engine if its a 4 Cyl.
OP if yours is a 4 Cyl read this thread. It will have everything you need yo know about consumption,
http://www.toyotanation.com/forum/10...ld-thread.html
Leaks will have to be cleaned off completely and then the car ran to find the leak source.
My Toyota List:
1982 Corolla SR-5 1JZGTE M/T
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is online now
The Following User Says Thank You to hardtopte72 For This Useful Post:
Kellebell66 (12-11-2012)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
Back
