Fog Light help! 03 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 12-22-2012, 08:33 AM Thread Starter
Fergifruitchew's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I have a 2002 camry LE Japan built, i popped out the fog light plastic parts and stuck in OEM fog lights and plugged in the connector that was already there. i bought a signal stalk with the seperate fog light ring on it. I have one problem, in the plug connector for the signal stalk in pin 10 and 11, i only have a wire in pin 10. and none in 11. i dont know why. so what can i do here. im in Canada if that matters.
Some pics.
[IMG][/IMG]
[IMG][/IMG]
Fergifruitchew is offline
post #2 of 6 Old 12-22-2012, 07:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I just checked on a few things under the dash on fuse panel. There is NO FOG relay but theres a spot to install the relay, I have a FOG fuse (15A) and it has power. I do not understand why my car is missing 50% of this OEM install... any suggestions? anyone?
post #3 of 6 Old 12-22-2012, 08:15 PM
Modder
apsbainc's Avatar
Quoted: 4 Post(s)
It looks like your missing the whole thing:
Use the info here to create your own relay and switch wiring.
http://www.toyotanation.com/forum/10...ml#post2742837
apsbainc is offline
post #4 of 6 Old 12-22-2012, 08:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thx, its just odd that my camry is missing half of the required wires... the grey wire gets spliced into the low beam wire and the red yellow goes to the relay. it should work then.
post #5 of 6 Old 12-25-2012, 06:25 PM
Senior TN Member
Quoted: 5 Post(s)
Why does this seem so strange? If you vehicle wasn't equipped with the actual fog lights, why would the manufacturer go to all the expense to put in all the wiring & controls for fog lights? Of course they won't. If you want fog lights in a non-fog light car, you should find a good donor car with fog lights and take parts off of that one until you have yours completed properly.
93celicaconv is offline
post #6 of 6 Old 12-25-2012, 08:08 PM
Modder
apsbainc's Avatar
Quoted: 4 Post(s)
The problem is, he has the wiring that's integrated into the lighting harness, but not the accessory harness. So unless he wants to replace the whole accessory control harness, its a lot easier to run a couple wires and a relay... My $ .02
apsbainc is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
Back
