2003 Toyota Camry gas leak problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2003-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 09-02-2013, 04:57 PM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
Yesterday I filled up my 2003 Camry completely filled to the top with gasoline so I could do a mileage check, and then drove 8 miles home.
Well today I went outside to find a small putter of a gas leakage underneath the car directly in the center of rear axle between the rear tires, were I believe the gas tank may be located.
Can anyone tell me why they may be a small leakage located there, why this is happening, and what should I do about this problem?
satman858 is offline
post #2 of 6 Old 09-02-2013, 05:48 PM
Quoted: 1 Post(s)
There are a lot of lines located in that area. The charcoal canister sits over your rear crossmember between the rear wheels.
FireLikeIYA is offline
post #3 of 6 Old 09-03-2013, 12:20 AM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
This evening I went to the store and on the way back home the car started missing and when reducing speed the engine almost killed.
Could filling the car to the very top caused problems like this?
Also, if I just got some bad gas what can I do?
post #4 of 6 Old 09-03-2013, 11:16 PM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
I wish I could get some answers to my post above.
post #5 of 6 Old 09-04-2013, 11:45 AM
ASE Master Technician
JSM1284's Avatar
Quoted: 1 Post(s)
Topping it off over the auto stop on the pump will cause the canister to become saturated with fuel and leak causing problems. You probably need to remove and attempt to drain the evap canister and lines of raw fuel. You may need to repalce it.
2013 Chevrolet Volt
2006 Lexus GS430(SOLD)
2001 Lexus IS300(SOLD)
2000 Celica GTS 6-Speed(SOLD)
2005 Lexus ES330(SOLD)
2002 Lexus ES300(SOLD)
2007 Camry SE V-6 Titanium(SOLD)
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline
The Following User Says Thank You to JSM1284 For This Useful Post:
Donald E. George (09-08-2013)
post #6 of 6 Old 09-04-2013, 02:14 PM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
I am going to try Heet this evening to try removing any water and condensation that many have occured with the warm humid weather we have here in the New Orleans La area.
P.S. It appears that the canister is no longer leaking, as I am no longer seeing a small gasoline puddle.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2002-2008)
User Tag List
Linear Mode Linear Mode
« Back
