A/C light blinking - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #16 of 115 Old 10-09-2007, 11:29 AM
07 Camry XLE V6
Quoted: 0 Post(s)
I had the same issue occur last week Oct 03 2007. A/C light was flashing with no cold air. My camry is an 07 xle v6 with a July 2007 build date with only 710 miles on the Odometer. I took it to the dealership first thing in the morning and they gave me the car back 30 minutes later fixed. All they did was replace the MG CLT Relay.
2007 Camry XLE V6
tiswicked is offline
post #17 of 115 Old 10-10-2007, 08:54 PM
Quoted: 0 Post(s)
Question 2004 Camry SE AC light blinking
This just started occurring on my wife's camry. Is the same relay replacement hold true for an 04'? Can anyone give a part number for this?
Please advise.
boatbuilder is offline
post #18 of 115 Old 10-11-2007, 09:20 AM
Quoted: 0 Post(s)
The 07 I cant help you with for now, but I will keep you posted.
The part number for 02 through 06 camry is TO90987-02028.
Keep in mind the need for this part was more than the vendor could handle, so these relays were on back order for most of the summer. Availability may be better now. Check it out at your local dealer. The part is cheap, $50 give or take $10 depending on your region.
Hope this helps. BTW this is a updated part number, so they have identified the problem with the old relay and fixed it. Make sure that you don't settle for the old part number.
buckerboo is offline
post #19 of 115 Old 01-09-2008, 06:23 PM
Registered User
Quoted: 0 Post(s)
USA it is the MG clutch relay
This same blinking light happen to me today and I changed the relay in the fuse box next to battery. It is a white relay. part number 90987-02022. went to dealer and charged me $64 for the part. they have changed the part to 90987-02028 now. I repalce it and worked like a charm. only regret was I could have bought the comparable relay at advance auto parts online for $14. Sucks.
vinh is offline
post #20 of 115 Old 01-25-2008, 09:13 PM
Quoted: 14 Post(s)
Blinking AC Light
Happens on wifes 02 Camry when the "Cabin Filter" gets dirty. (behind Glove Box). It is very easy to get to and replace. Open Glove box. Empty Glove Box. Take out phillips screw on dampener connection on the right of box. Squeeze together sides of glove box, and lower portion of box, that hinges on bottom comes off. Filter is on inside firewall. Light on AC will not stop immediately but only after a few starts and restarts over a few days. Or you could have the light reset at a Autozone for free by having them loan you a tool. Or disconnect the battery for 30 minutes, and put back on. Then you would have to reset the radio stations, and may notice the car idle being reset for the first few starts. But it works. CABIN FILTER , bought at Kragens or Autozone for around $21.
Microman is offline
post #21 of 115 Old 01-27-2008, 02:42 PM
Quoted: 0 Post(s)
Cabin filter will not cause the AC light to blink. The light blinks whenever there is an electrical or rotational malfunction with the compressor and or magnetic clutch assembly. The car doesn't know when the filter is dirty, it doesn't even know the filter is there.
Shop Foreman L&S Toyota of Beckley
2008 Prius Package #2
1971 M35A2.....Tha Deuce
toyotechwv is offline
post #22 of 115 Old 01-27-2008, 02:44 PM
TN's furry friend
Quoted: 0 Post(s)
iTrader Score: 17 reviews
sounds like it may be a loose wire, check the socket that plugs into the compressor
WhiteRabbit is offline
post #23 of 115 Old 01-27-2008, 04:55 PM
wonger's Avatar
Quoted: 8 Post(s)
this is very common on camrys and as stated before.. its the relay..
88 4Runner
wonger is online now
post #24 of 115 Old 03-12-2008, 05:52 PM
Quoted: 14 Post(s)
Relay Fixed it !!!! No flashing Light
Everyone was correct, even though I have a new Cabin Filter, and thought that was the only reason I would see the AC light flash, the Relay Fixed the problem.
Would have ordered the 16.99 one from Advance Autoparts, but they were OUT OF STOCK.
I did not want to spend, now >$70 at the dealer for this relay. And the junk yards had too many old cars.
I went to Autozone, where the had the Santech AC Relay. MT0610 for $27.99 with tax and FED EX Delivery to the store it was $30.30.
Plugged the thing in at Autozone, and the ride home was AC LIGHT FLASHING FREE.
This is an engineered replacement part from China.
THanks all for the great information!! 2002 Camry now fixed.
Microman is offline
post #25 of 115 Old 06-28-2008, 07:27 AM
Quoted: 0 Post(s)
Exclamation
I had the same problem this week. Replaced the A/C Relay with "A/C Relay Fctry" from Advance Auto Parts for $14.
But it doesn't seem to fix the problem.
The A/C will go full blast for a while, but then the "green flashing death light" starts in again.
Did I get a bum part, or is there possibly some other problem?
(P.S. I already replaced the air filter).
O.V.N. is offline
post #26 of 115 Old 06-28-2008, 12:26 PM
wonger's Avatar
Quoted: 8 Post(s)
did you replace the relay that says MG CLT Relay
88 4Runner
post #27 of 115 Old 06-29-2008, 06:40 PM
Quoted: 14 Post(s)
Make sure you changed the correct Relay, and Check the Cabin Filter.
Look in owners manual for instructions.
Microman is offline
post #28 of 115 Old 04-27-2009, 08:46 PM
FLIP'N THE G-5 WHIP
RICO8458's Avatar
Quoted: 0 Post(s)
Gen5
well brothers, i am here after researching and i have a 2005 camry with 83,000 miles, and yes, for the first time i got the a/c green light flashing/blinking thing too.
so i will try the relay after reading all of the good excellent advise here.
thanks,
Rico
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline
post #29 of 115 Old 04-27-2009, 11:26 PM
イリジウム
Quoted: 368 Post(s)
Check the compressor clutch. When the light is flashing, what happens to the clutch? Does it stop or slow?
In an otherwise fine (but old) system, the cause may be low refrigerant. If you are sure it's low, then Walmart has a kit for about $12 with a hose. One big can with a gauge I think is about $30. But don't overcharge.
JohnGD is offline
post #30 of 115 Old 04-28-2009, 10:44 AM
FLIP'N THE G-5 WHIP
RICO8458's Avatar
Quoted: 0 Post(s)
Gen5
compressor clutch seems to stop all the time.
RICO8458 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
Back
