where is the OBD connector located in 07 Camry? Does it provide constant 12V+ power? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 8 Old 08-18-2007, 10:20 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
where is the OBD connector located in the 2007 Camry?
Does it provide constant 12-volt positive power?
(even when vehicle is turned off with key removed)
THANKS!
ToyotaLexus is offline
post #2 of 8 Old 08-19-2007, 06:30 AM
Guest
Quoted: 14 Post(s)
Gen6 OBDII Location & Power
THANKS!
It is located under the dash, just to the right of the steering shaft cover, about 4 inches.
The print I found indicates that the +12v is located on pin #16 (OBDII Fuse @ 7.5A) and is always on, Ground on pin 4. This is a "CAN" compliant connector, 6 is CAN High & 14 is Can Low.
Luna2 is offline
post #3 of 8 Old 08-19-2007, 07:46 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks!
Is it a bad idea to keep keep the OBD connector plugged in on a permanent basis?
post #4 of 8 Old 08-19-2007, 08:45 PM
Guest
Quoted: 14 Post(s)
Gen6
Thanks!
Only if you watch its readout more than the road!
It will draw current if the OBDII reader is left on with the key removed.
Luna2 is offline
post #5 of 8 Old 08-19-2007, 09:00 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I guess the current draw shouldn't be that much...
My alarm system require a permanent connection to the OBDII connector.
(to scan/verify the VIN# whenever the car is started/turned-off)
post #6 of 8 Old 08-20-2007, 03:32 AM
Guest
Quoted: 14 Post(s)
Gen6 OBDII Connection
Is the connection at the connector? Or, are you going to splice the wires? If a connector is used, the end of the plug might hang too low, and show.
Luna2 is offline
post #7 of 8 Old 08-20-2007, 09:17 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks for your help!
I looked under the dash and sure enough, the OBD connector is on the right.... I was looking
for it on the left side, near the hood release.(which is where the OBD connector is located on
all the other cars I've owned in the past) I feel so stupid... if only I turn my head to the right,
I would have seen it...
I took the OBD connector off and plugged into a OBD Y-adaptor/harness, then put one end
of the Y-adaptor back into the original OBD location.(in case a Toyota tech, or a state
emission inspector, need to plug it in)
post #8 of 8 Old 08-20-2007, 10:49 AM
Guest
Quoted: 14 Post(s)
GRRRRREAT!!!
Luna2 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
« Back
