Tire Pressure Sensor Light - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 1Likes
  • 1 Post By Ae95/4agze
post #1 of 15 Old 10-18-2007, 02:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA Tire Pressure Sensor Light
I recently had my tires rotated and ever since have had a problem with the tire pressure sensor light in the car. I have reset it, but it keeps coming back on. This has been going on for about a month. Yesterday, I took the car back to where I had my tires rotated. They confirmed my tire pressure is fine in all of my tires. Whats up with this? How can I get the light to stay off?
Patty is offline
post #2 of 15 Old 10-19-2007, 07:44 AM
I smell McNuggets
[SMAN]'s Avatar
Quoted: 0 Post(s)
iTrader Score: 7 reviews
What year is the car?
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline
post #3 of 15 Old 10-19-2007, 06:54 PM
Pissed
Quoted: 0 Post(s)
Is there a full size spare? if so check the tire pressure in the spare, if its low that may be the prob? do you have sensors? or rubber valve stems?
Camryamnesty is offline
post #4 of 15 Old 10-21-2007, 09:35 AM
Quoted: 4 Post(s)
The exact same thing happened in my '04. I was not happy that the dealerships were such dummies about it. They were not helpful and I did a lot of running around for them not to fix it.
If something is wrong other than a reset this won't work.
Next time you are at a long stop light with the car fully stopped press and hold in the reset button for at least 15 seconds. More if you can. This should resolve it. I've had to do it a few times after rotations and it has worked every time so far.
Xander Crews is offline
post #5 of 15 Old 10-21-2007, 09:49 AM
I smell McNuggets
[SMAN]'s Avatar
Quoted: 0 Post(s)
yeah I had to reset mine as well. The 04 has a different system than the 06+ It uses the speed sensor on all 4 wheels, if 1 doesn't match, it throws the light. Mine was acting up lately, and i knew i had good pressure. So yeah the owners manual says how to reset it, but i think you have to be in park or have the parking break on or something while you hold it down for a while. You'll have to double check the manual.
[SMAN] is offline
post #6 of 15 Old 11-16-2007, 12:07 PM
Quoted: 0 Post(s)
USA
Patty, I just bought my daughter a new 07 Solara this Monday. She drove it from Jacksonville to Tallahassee and by the time she got there, the air pressure light was on. She called home and was really upset that her brand new car was already broken. She took it to a Toyota dealer the next day and they found all four tires low. I spoke to my dealer who was really surprised as they had just mounted the tires Monday night. He said it may be faulty valve stems and he'll replace them if it happens again. The stems have a chip in them that may have been damaged. The car was made in March and has been sitting around undriven until now, kit only had five miles on it (why?). Maybe this is your problem. Do you like your Solara?
Froghair is offline
post #7 of 15 Old 11-16-2007, 05:09 PM
Quoted: 0 Post(s)
My wife's did this last night after a rotation. Its an 06. I waited until the next morning for the pressure to stabilize with the cold front we just got. Set all 4 within .5 pounds. Turn the ignition to the run position and pushed the reset in until the indicator flashed three times. Problem solved.
lostru is offline
post #8 of 15 Old 08-31-2015, 10:37 AM
Vbt
Quoted: 0 Post(s)
I have done all those things and taken it to local dealership. Nothing works. Help?
Vbt is offline
post #9 of 15 Old 09-01-2015, 12:10 AM
Quoted: 0 Post(s)
You took it to the dealership? What did they say?
For me, the monitors are very sensitive. Have you checked your tire pressure and made sure they're all equal?
I also had this problem when I didn't reset it properly, but the tire shop did something to mine (broke it) because it never comes on anymore.
Cosmic Grooves is offline
post #10 of 15 Old 09-01-2015, 02:34 AM
Vbt
Quoted: 0 Post(s)
I love my dealership but they were clueless. Took vehicle in on three separate occasions and each time the service mechanics would reset it. After driving approximately three miles, it would pop back on. Finally, service department said that it isn't a bad problem. In other words, not going to effect the drivability of the automobile. Gotta love service techs. With myour light, it sometimes will stay off a day, then pops on. I've given up.
Vbt is offline
post #11 of 15 Old 09-02-2015, 10:33 PM
Quoted: 0 Post(s)
Are you certain your following the reset procedures correctly? I don't have my manual right now to check it.
post #12 of 15 Old 09-02-2015, 11:21 PM
Vbt
Quoted: 0 Post(s)
I have done as instructed per the manual. It stays off sometimes for a day or two, then turns on and then will turn off.
Vbt is offline
post #13 of 15 Old 09-03-2015, 08:50 PM
Quoted: 0 Post(s)
Do you have an accurate tire gauge to make sure all pressure is equal? If I had a tire that was just a of couple PSI off, the light would come on.
Mine seemed to come on most often when driving higher speeds/freeway, etc.
post #14 of 15 Old 09-03-2015, 11:40 PM
Quoted: 16 Post(s)
Tire lights are a great fustration for both customers and dealers. Tire monitoring systems are a goverment mandated system. The first version toyota used a microphone and speed sensor to tell if a tire was low on air. The thing is that a change in altitude or temp can cause tire pressure to changes has much has 3 to 5 psi.
On the older system that use the speed sesnor. When it does not want to reset correctly after a tire rotate or replacement. Try doing the reset twice in a row. This is vehicle on, in park press and hold the reset button down tell the tire light starts flashing. Continue to hold the button tell the light stops flashing. Then wait a few seconds and do it again. This second time will cause the system to reset the threshold for when it will turn the light on.
If it is the newer system with the sensor built into the valve stem. Then it needs to be done with a tpms tool or a scan tool with the capbiltiy.
beerhunt likes this.
Ae95/4agze is offline
post #15 of 15 Old 12-20-2015, 10:54 AM
Quoted: 0 Post(s)
Where is the reset button?
missg777 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
Back
