Anyone replace AC clutch on 02 Camry AC compressor - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 04-09-2008, 01:15 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
[I want to know if I want to replace the AC clutch on the ac compressor, do I have to remove the whole compressor to change the clutch or can I just remove the clutch. I don't want any freon to release and need to put in back in again. Also, is the bearing inside the clutch itself? Please advice. thanks
toyo9494 is offline
post #2 of 6 Old 04-09-2008, 05:29 PM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
I haven't worked on this exact model so I am being generic. The pulley rides on a sealed bearing on the compressor shaft and should be attached to the end of the shaft by a single bolt. You would need to loosen and remove that bolt. Second, there are likely 2 or 3 tapped holes in the outer surface of the clutch to be used for pressing the clutch off the compresor shaft. You will need a bearing puller/press of some sort that will match up to these holes. Don't hammer or bang hard on the pulley or you will end up buying a new clutch assembly. The shafts are generally tapered so once it pops loose it should slide right off. There will be a key in the shaft so don't loose it either.
Start by finding a puller to do the proper job. With the belt still attached, crack the center bolt loose and then remove the belt. Remove the center bolt and bolt on the press. You might need to buy a couple bolts to match the threads on the pulley holes.
The bearing should be held in place inside the pulley by a snap ring. Remove the ring using snap ring pliers and then press out the bearing using a press or a mallet and large drift.
gdanaher is offline
post #3 of 6 Old 04-10-2008, 10:28 AM
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
Quoted: 3 Post(s)
If you want accurate advice, it's a good idea to at least give the year, model, and engine size. You only excluded the engine, but it can make a difference.
You will probably have to at least loosen the compressor from it's mounting location so that you can gain access for pulling off the clutch and installing the new one. That's fairly common on transverse engine layouts.
I've replaced compressor clutches on the vehicle when the compressor location permits it.
2006 Camry LE Special Edition
TRD VVTi is offline
post #4 of 6 Old 04-10-2008, 10:41 AM
ASE Master Technician
JSM1284's Avatar
Quoted: 2 Post(s)
Service and RepairREPLACEMENT
  1. DISCHARGE REFRIGERANT FROM REFRIGERATION SYSTEM SST 07110-58060 (07117-58080, 07117-58090, 07117-78050, 07117-88060, 07117-88070, 07117-88080)
  2. REMOVE FAN AND GENERATOR V BELT SST 09249 - 63010
  3. REMOVE GENERATOR ASSY
  1. DISCONNECT COOLER REFRIGERANT DISCHARGE HOSE NO.1
    1. Remove the nut and disconnect the cooler refrigerant discharge hose No.1.
    2. Remove the O-ring from the cooler refrigerant discharge hose No.1.
NOTE:</B> Seal the opening of the disconnected parts using vinyl tape to prevent moisture and foreign matter from entering.
  1. DISCONNECT COOLER REFRIGERANT SUCTION HOSE NO.1
    1. Remove the nut and disconnect the cooler refrigerant suction hose No.1.
    2. Remove the O-ring from the cooler refrigerant suction hose No.1.
  1. REMOVE COMPRESSOR AND MAGNETIC CLUTCH
    1. Disconnect the connector
    2. Remove the nut.
    1. Using a torque socket wrench (E8), remove the bolt.
    1. Remove the 3 bolts and compressor and magnetic clutch.
  1. REMOVE MAGNET CLUTCH ASSY
  1. Remove the bolt and bracket.
  2. Place the compressor and magnetic clutch in vise.
  1. Using a vise pliers, hold the magnet clutch hub.
  2. Remove the bolt, magnet clutch hub and magnet clutch washer.
  1. Using a snap ring expander, remove the snap ring and magnet clutch rotor.
  2. Disconnect the connector.
  1. Using a snap ring expander, remove the snap ring and magnet clutch starter.
    1. REMOVE COOLER COMPRESSOR ASSY
    2. INSTALL MAGNET CLUTCH ASSY
  1. Matching the parts shown in the illustration, install the magnet clutch starter.
  1. Using a snap ring expander, install a new snap ring with the chamfered side facing up.
  2. Connect the connector.
  1. Using a snap ring expander, install the magnet clutch rotor and a new snap ring with the chamfered side facing up.
  2. Install the magnet clutch washer and magnet clutch hub.
NOTE:</B> Do not change the combination of the magnet clutch washers used before disassembly.
  1. Using a vise pliers, hold the magnet clutch hub and install the bolt. Torque: 18 N.m (184 kgf.cm, 13 ft.lbf)
    1. INSPECT MAGNETIC CLUTCH CLEARANCE
  1. Set the dial indicator to the magnet clutch hub.
  2. Connect the battery positive lead to the terminal 3 of magnet clutch connector and the negative lead to the earth wire. Turn on and off the magnet clutch and measure the clearance. Standard clearance: 0.35 - 0.60 mm (0.014 - 0.024 in.) If the measured value is out of the standard range, remove the magnet clutch hub and adjust it with magnet clutch washers.
NOTE:</B> Adjustment shall be performed with 3 or less magnet clutch washers.
  1. Remove the compressor and magnetic clutch from the vise.
  1. Install the bolt and bracket.
    1. INSPECT COMPRESSOR OIL
      1. When replacing the compressor and magnetic clutch with new one, after gradually removing the refrigerant gas from the service valve, drain the following amount of oil from the new compressor and magnetic clutch before installation. Standard: (Oil capacity inside new compressor and magnetic clutch: 120 + 15 cc (4.1 + 0.51 fl.oz.) ) - (Remaining oil amount in the removed compressor and magnetic clutch) = (Oil amount to be removed when replacing)
NOTE:</B>
  • When checking the compressor oil level, observe the precautions on the cooler removal/installation.
  • Because compressor oil remains in the pipes of the vehicle, if a new compressor and magnetic clutch is installed without removing some oil inside, the oil amount becomes too much, preventing heat exchange in the refrigerant cycle and causing refrigerant failure.
  • If the remaining oil in the removed compressor and magnetic clutch is too small in volume, check for oil leakage.
  • Be sure to use ND-OIL8 for compressor oil.
    1. TEMPORARY TIGHTEN COMPRESSOR AND MAGNETIC CLUTCH
      1. Temporarily the compressor and magnetic clutch with the 3 bolts.
    1. FULLY TIGHTEN COMPRESSOR AND MAGNETIC CLUTCH
      1. Using a torque socket wrench (E8), install the bolt. Torque: 25 N.m (250 kgf.cm, 18 ft.lbf)
      2. Tighten the compressor and magnetic clutch with the 3 bolts and nut. Torque: 25 N.m (250 kgf.cm, 18 ft.lbf)
      3. Connect the connector.
NOTE:</B> Tighten the bolts and nuts in following order shown in the illustration to install the compressor magnetic clutch.
      1. Remove the attached vinyl tape from the hose.
      2. Sufficiently apply compressor oil to the new O-ring and fit surface of the compressor and magnetic clutch. Compressor oil: ND-OIL 8 or equivalent
      3. Install a O-ring to the cooler refrigerant suction hose No.1.
      1. Install the cooler refrigerant suction hose No.1 to the compressor and magnetic clutch with the nut Torque: 9.8 N.m (100 kgf.cm, 87 in.lbf)
      3. Install a O-ring to the cooler refrigerant discharge hose No.1.
      1. Install the cooler refrigerant discharge hose No.1 to the compressor and magnetic clutch with the nut. Torque: 9.8 N.m (100 kgf.cm, 87 in.lbf)
    1. INSTALL GENERATOR ASSY
    2. INSTALL FAN AND GENERATOR V BELT SST 09249-63010
    3. CHARGE REFRIGERANT SST 07110-58060 (07117-58060, 07117-58070, 07117-58080, 07117-58090, 07117-78050, 07117-88060, 07117-88970, 07117-8080) Specified amount: 550 ±50 g (19.37 ±1.76 oz.)
    4. WARM UP ENGINE
    5. INSPECT LEAKAGE OF REFRIGERANT
2013 Chevrolet Volt
2006 Lexus GS430(SOLD)
2001 Lexus IS300(SOLD)
2000 Celica GTS 6-Speed(SOLD)
2005 Lexus ES330(SOLD)
2002 Lexus ES300(SOLD)
2007 Camry SE V-6 Titanium(SOLD)
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline
The Following User Says Thank You to JSM1284 For This Useful Post:
gugu239 (04-14-2011)
post #5 of 6 Old 04-10-2008, 01:09 PM
TRD VVTi's Avatar
Quoted: 3 Post(s)
^ Great info, as usual.
You still don't have to completely remove the compressor though. You only need to move it to provide access for tools.
TRD VVTi is offline
post #6 of 6 Old 04-10-2008, 01:26 PM
JSM1284's Avatar
Quoted: 2 Post(s)
If there is enough slack there to move it enough....
2013 Chevrolet Volt
JSM1284 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
« Back
