Power Steering fluid for 2007 Camry i4 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 12 Old 07-23-2008, 09:07 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have 40k miles on my Camry and thought it would be a good time to replace my power steering fluid. The power steering bottle cap says " Dex II or Dex III transmission fluid".---- Fluid is goldish black, not red
I called 'Gullo Toyota, Conroe, TX' and asked what fluid I should use and they said they only use the regular power steering fluid and not the Dex transmission fluid for the power steering.
I don't trust them because when I did a drain and fill on my transmission last week they insisted that I have the Type IV fluid and I had to drag them out to the parking lot to pull my dip stick and shock them that it says "Type WS" on it. I wonder how many other poor souls have been screwed over because of them giving the wrong transmission fluid. In other words, I don't think they know squat..... or they need to be retrained.(Gullo Toyota)
Question is ...... Is it ok to use regular power steering fluid or do I have to use Dextron III transmission fluid?
Thanks fellas!
stdrxw12 is offline
post #2 of 12 Old 07-23-2008, 10:44 AM
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
Quoted: 3 Post(s)
Thanks fellas!
"The power steering bottle cap says " Dex II or Dex III transmission fluid".---- "
You already answered your own question.
I use Mobil 1 synthetic ATF in my power steering systems.
2006 Camry LE Special Edition
TRD VVTi is offline
post #3 of 12 Old 07-23-2008, 10:55 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yes, but is not the Dex fluid Red?.... I have Gold in my power steering tank?.... What fluid is that? What happens when I mix the red Dex III transmission fluid and the existing goldish black fluid?
stdrxw12 is offline
post #4 of 12 Old 07-23-2008, 10:57 AM
TRD VVTi's Avatar
Quoted: 3 Post(s)
The color will become more red when you add red fluid...
It's not as complicated as you're making it out to be.
TRD VVTi is offline
post #5 of 12 Old 07-23-2008, 03:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
What fluid is the gold fluid that comes as factory fill?.... just curious... I'm not sure why Dex won't be used as factory fill?
stdrxw12 is offline
post #6 of 12 Old 07-23-2008, 04:17 PM
TRD VVTi's Avatar
Quoted: 3 Post(s)
Power steering fluid quickly becomes discolored. It doesn't matter if it's power steering fluid or ATF.
TRD VVTi is offline
post #7 of 12 Old 07-23-2008, 06:36 PM
Toyota | moving forward
islandboy57's Avatar
Quoted: 29 Post(s)
I was under the impression that it's just a dye. In other words, it doesn't matter. I put Dexron III ATF fluid in my gen 3.5's PS reservoir without any problems. My gen 5.5's PS fluid is still pretty clear looking so I am not worrying about it.
'16 Camry LE - 3K miles
'15 Camry SE - 11K miles
'13 Corolla LE - 18K miles
islandboy57 is offline
post #8 of 12 Old 07-23-2008, 08:01 PM
touringcamry's Avatar
Quoted: 3 Post(s)
What makes you think it's not Dex III? I highly doubt that the factory won't use the specified fluid especially since it produces several hundred thousand vehicles per year. I think that would result in a huge recall and bad press.
Power steering fluid can be any color you like. It just depends on the coloring.
If you are in doubt, mix motor oil and brake fluid until you have a color and consistency that you like for your power steering fluid replacement. Oh, throw some Zerex G05 coolant in there too.
2007 Camry 2.4L 5M
touringcamry is offline
post #9 of 12 Old 07-23-2008, 08:45 PM
Joined the dark side. :D
workerant's Avatar
Quoted: 925 Post(s)
Wow.. really? only 40K and they need changing? Than I need to change mine too. LOL
workerant is offline
post #10 of 12 Old 07-23-2008, 09:09 PM
Quoted: 29 Post(s)
Some of you guys sure drive a lot. The OP is at 40K on his '07. I'm at 28K on my '05!
post #11 of 12 Old 07-23-2008, 09:41 PM
workerant's Avatar
Quoted: 925 Post(s)
Well.. for me I bought my car to drive. Not just to do car wash.
post #12 of 12 Old 06-11-2009, 06:44 AM
Quoted: 12 Post(s)
Thanks fellas!
I used NAPA Power steering for my all Toyota's.
http://napaonline.com/MasterPages/NO...Steering+Fluid
can you explain me drain and fill for transmission for your 07 camry.
I know you should use "World standard" .
My 07 and 09 I4 camry has dipstick to check level. is that you used to refill?
Thanks,
camlex is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
« Back
