08 camry se v6 drives better with 89 gas why? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 17 Old 08-10-2008, 07:56 PM Thread Starter
Quoted: 9 Post(s)
(Thread Starter)
Gen6 08 camry se v6 drives better with 89 gas why?
Since i bought my 2008 camry se v6, i been putting 87 gas. Recently i started using 89 and noticed different in how the car drives. It seem acceleration is better with 89 gas instead of 87. Looking at the manual, recommendation is for unleaded gas only. So why it feels like it's driver better with higher gas when car is designed for lower gas?
ylen13 is offline
post #2 of 17 Old 08-10-2008, 08:05 PM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
It's largely your imagination. It might account for perhaps 1 additional horsepower which would hardly be measurable by test equipment let alone an untrained human.
gdanaher is offline
post #3 of 17 Old 08-10-2008, 08:06 PM
Quoted: 1 Post(s)
Gen6
Oil Company conspiracy........
Try 91, 93 and then 95 and it will really feel great.
njerald is offline
post #4 of 17 Old 08-10-2008, 08:22 PM
Quoted: 0 Post(s)
Doesn't higher octane gas require higher temperature/pressure to detonate? Wouldn't this reduce performance in an engine designed for lower temperatures/pressures? The slower burning, higher octane fuel can also lead to carbon deposits if it is not completely combusted.
pepperdanky is offline
post #5 of 17 Old 08-10-2008, 09:10 PM
Quoted: 0 Post(s)
our low compression ratio engine do not benefit from running higher octane fuel, I saw a consistent 2~3mpg drop whenever i switched from 87 to 93.
2009 Toyota Camry LE V6
2005 Toyota Camry SE V6
ben805 is offline
post #6 of 17 Old 08-10-2008, 09:15 PM
Quoted: 1 Post(s)
Gen6
10.8:1 is not low compression except maybe to kids.....
njerald is offline
post #7 of 17 Old 08-10-2008, 09:18 PM
Senior TN Member
geoff5093's Avatar
Quoted: 1 Post(s)
89 is also unleaded gas...
geoff5093 is offline
post #8 of 17 Old 08-10-2008, 11:04 PM
No Mod can stop me
centennialman's Avatar
Quoted: 0 Post(s)
SE Every other trim
centennialman is offline
post #9 of 17 Old 08-10-2008, 11:20 PM Thread Starter
Quoted: 9 Post(s)
(Thread Starter)
Well maybe it's all in my head. Not sure, it sure feels like car is driving better with 89.
ylen13 is offline
post #10 of 17 Old 08-11-2008, 12:12 AM
2007 Camry SE V6
Quoted: 0 Post(s)
I primarily use 87, but occasionally put in 91. Maybe some of you think that there is no difference in performance between the two, but I definitely see a difference. Not enough to justify the cost difference, but still very noticeable.
2007 Camry V6 SE, Blue Ribbon Metallic, UR Strut/Sway Bar, Magnaflow mufflers, H&R Springs, TSW Nurburgring 18x8, Reus Sound System, More
SOLD!!
thrawnis is offline
post #11 of 17 Old 08-11-2008, 02:25 AM
Quoted: 0 Post(s)
10:8:1 is certainly LOW enough for Toyota to suggest 87 octane to be use, they would have recommended 91 or higher octane if by your definition it ain't no low compression.
ben805 is offline
post #12 of 17 Old 08-11-2008, 02:36 AM
Rapid Roy's Avatar
Quoted: 2 Post(s)
What is your mileage increase when using higher octane gas? Seat of the pants evaluations are to subjective.
Rapid Roy is offline
post #13 of 17 Old 08-11-2008, 12:55 PM
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
Quoted: 3 Post(s)
There's no way that you're actually "feeling" the difference.
10.8:1 compression is not low. The engine being made of aluminum, electronic fuel injection, and efficient cooling systems are just a few reasons why Toyota and other manufacturers can run a high compression ratio like 10.8:1 without detonation on 87 octane fuel.
Running a higher octane does take longer to burn and can lead to more deposits.
I'm guessing that the OP's car is loosening up and feels more powerful, but it's not the extra 2 octane causing this.
2006 Camry LE Special Edition
TRD VVTi is offline
post #14 of 17 Old 08-11-2008, 02:19 PM
2007 Camry SE V6
Quoted: 0 Post(s)
I have not noticed a significant difference in gas mileage between 87 and 91.
SOLD!!
thrawnis is offline
post #15 of 17 Old 08-11-2008, 03:09 PM
Quoted: 0 Post(s)
not on the camry but in my other car i used 91 premium all the time but when gas prices shot up i went to 87 and i did feel a difference. not so much in hp cus its not going to miraclely add 20hp but i feel it in acceleration. better detonation using 91 than compared to 87.
jcurtin06 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
Back
