Diagnostic Reading HELP: Code P2238 on 2004 Camry 4cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 11 Old 08-20-2008, 07:59 PM Thread Starter
MCeatalot's Avatar
Quoted: 0 Post(s)
iTrader Score: 7 reviews
(Thread Starter)
My brother's 04 Camry just had a readout of Code P2238. His car has roughly 105,000 miles on it. A quick search in this forum gives a single mention of the code, but with no definite answer. Can anyone please help provide more answers as to what Code P2238 is and how to fix it? Thanks.
I replaced my 4-cyl with another 4-cyl, equally powered, but faster ride...
http://i234.photobucket.com/albums/e...e/P9231851.jpg
MCeatalot is offline
post #2 of 11 Old 08-20-2008, 09:22 PM
Loving the camry =)
Quoted: 0 Post(s)
where did u get the readout from? autozone usually does free diagnostic and code interpretation.
skyxliner is offline
post #3 of 11 Old 08-20-2008, 09:37 PM
Quoted: 1 Post(s)
Diagnostic procedures are in the Service Manuals.
His GEN5 is probably similar to your GEN6 so you could look in yours.
njerald is offline
post #4 of 11 Old 08-20-2008, 10:34 PM Thread Starter
MCeatalot's Avatar
Quoted: 0 Post(s)
(Thread Starter)
He got it from an OBD reader purchased at Kragen or Autozone, I believe.
Diagnostic procedures are in the Service Manuals. Njerald, by Service Manual, are you referring to the Haynes Manual? If you are, we don't have that.
If anyone else has had this problem on their Gen 5, please share your experience. Thanks!
post #5 of 11 Old 08-20-2008, 10:41 PM
Quoted: 1 Post(s)
Toyota Service Manual.
You've been a member for over a year and haven't downloaded it?
Try the sticky area........
njerald is offline
post #6 of 11 Old 08-20-2008, 11:08 PM
Former Toyota/ASE Master
Qslim's Avatar
Quoted: 1 Post(s)
Check out the bottom of this page. Most often with this code your problem is going to be the AF sensor.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline
post #7 of 11 Old 08-21-2008, 10:37 AM
2004 Camry LE
somick's Avatar
Quoted: 37 Post(s)
O2 Sensor Positive Current Control Circuit Low
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline
post #8 of 11 Old 08-21-2008, 12:50 PM Thread Starter
MCeatalot's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Oh haha! Guilty as charged. I've never bothered downloading that. Thanks for the heads up!
My brother and I finally figured out that it's the A/F sensor. Thanks!
post #9 of 11 Old 03-18-2010, 11:29 AM
antb2009's Avatar
Quoted: 0 Post(s)
i got the same read out just now,how much did it cost and where did you buy it?
need help with this, please help
antb2009 is offline
post #10 of 11 Old 03-18-2010, 02:37 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 10 Post(s)
oxygen sensors usually are designed to last up to 100k miles. get the replacement either Denso (factory) or NTK (made by NGK company).
if you want OEM (denso) go to online toyota retailer and look there by part number or go with NGK:
http://www.ngksparkplugs.com/part_fi...uv/default.asp
you can check toyota factory part number here (search for "oxygen sensor"):
http://www.toyodiy.com/parts/
get the NGK model number or OEM part number for your car and look for it on internet stores like rockauto.com or amazon.com
rockauto may carry denso parts cheap. amazon usually stocks ngk mostly at good prices. you may also try ebay, sometimes you can find real deals over there.
most local stores will charge you an arm and leg for A/F sensor.
'02 Solara SLE V6 1MZ-FE/A541E@ 154k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
fenixus is offline
The Following User Says Thank You to fenixus For This Useful Post:
antb2009 (03-18-2010)
post #11 of 11 Old 07-07-2016, 09:37 PM
Quoted: 5 Post(s)
I have same problem since for more than a year. I have tried different things, like changing the HO2(A/F) still the code coming. I also change the Coolant Temperature Sensor, it improved the A/F ratio, since I had a lot of cylinder knocking. I still running under this code, with minor issues. I know Toyota has issue a Technical Bulletin EG032-04 M.I.L. ON" DTC P0031 AND/OR P2238, regarding this problem. They just Change the HO2 sensor type and re-program the sensor calibration in the ECU. They also install a new hood label to document the change. I went to the dealer they will not do it for my 2004 Camry LE 2AZFE since it has pass warranty terms. That will be billed to me. So I decided to wait. I have done all testing, monitoring and inspection, all voltages are between 0.5 and 4.5V, no open, no grounded or no short circuit in the sensor, Heater resistor between 1.8-3.4ohms, voltages from ECU inputs open collectors are under specifications 3V and 3.3V…cables and plugs between ECU and HO2 are ok….Fuse A/F HTR is OK…HTR Relay not for this model….
Regarding to the link njerald posted....I am looking for Service Manual on a PDF files for my 2001 Toyota Corolla without luck. Any help will be appreciated.
guaitiao is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
« Back
