2009 I4 5W20 or 5W30 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 30 Old 11-24-2008, 09:33 PM Thread Starter
Quoted: 12 Post(s)
(Thread Starter)
Hello,
It's time for my 09 camry oil change. it's 4 cylinder car.
I have others vehicles Sienna (140,000), 2002 Camry(80,000)
and ES300 with 337,200. in all my car i do oil change at 5,000 or six month
with Castrol synthetic blend 5W30.
I don't like to keep so many types of oil.
Can i use 5W30 syn.blend for 2009 camry?
Thanks in advance.
camlex is offline
post #2 of 30 Old 11-24-2008, 09:35 PM
Quoted: 1 Post(s)
Gen6
Originally Posted by camlex View Post
Hello,
Thanks in advance.
You can use anything you want.
Toyota calls for 0w20 or 5w20..........according to your Owners Manual.
njerald is offline
post #3 of 30 Old 11-24-2008, 10:53 PM
Quoted: 12 Post(s)
So in other words you might void your warranty for not using the recommended oil viscosity. If it was me at least for the warranty period I would stick to what the manual calls for and also make sure that you keep all the receipts.
89molavi is offline
post #4 of 30 Old 11-25-2008, 09:54 AM
Quoted: 0 Post(s)
According to the manual, "an oil with a higher viscosity may be better suited if the vehicle is operated at high speeds, or under extreme load conditions". This can be found under your lubrication specs in your manual. This would indicate that you CAN run a 5W-30 oil in your engine.
Should you do so? If you are towing or do high speed runs, maybe... In normal driving however I would stick to the recommended viscosities. The engine clearances and oil pump are designed to use this oil.
I understand your problem though as I had 2 types of oil at my house. When that happened, I just used a different brand of oil for the cars. The "yellow" bottle (Pennzoil Platinum) went into the truck and the “silver” bottle (Mobil 1) went into everything else.
GeorgiaHybrid is offline
post #5 of 30 Old 11-25-2008, 09:59 AM
Back to Toyota
jaysi09's Avatar
Quoted: 19 Post(s)
Our dealer uses 5W-30 on my parent's V6 camry. not sure if that applies to the I4 as well.
2014.5 Camry SE V6
TRS 5K HIDs, TRS XB LED Foglights
2016 Honda Accord EX-L V6
jaysi09 is offline
post #6 of 30 Old 11-25-2008, 10:03 AM
Quoted: 0 Post(s)
Jazs,
The I4 is recommended to use 0w-20 or 5w-20. The specs on the V6 are different.
post #7 of 30 Old 11-25-2008, 10:27 AM
LOV
268 HP OWNER
LOV's Avatar
Quoted: 0 Post(s)
Originally Posted by GeorgiaHybrid View Post
Jazs,
Yep for V6 its 5w-30 and for i4 (0)5w-20.
2007 Camry SE V6 , MGM
LOV is offline
post #8 of 30 Old 11-25-2008, 11:17 AM
Quoted: 1 Post(s)
Gen6
That may be incomplete answer.
The V6 has 5w20 specified for it, if it meets ILSAC GF-4 specs......beginning with the '06 models according to the TSB.
The TSB does say as a contradiction, that the recommended grade on your engine cap or in your Owners Manual should be used.
I'm sure of my grade with an I4.
njerald is offline
post #9 of 30 Old 11-25-2008, 03:46 PM Thread Starter
Quoted: 12 Post(s)
(Thread Starter)
I thought 5W for cold viscosity and 20/30 for additive to keep viscosity at higher temp.
Texas is known for heat. As long as you use 5W cold starting viscosity you will be fine.
Correct me if i am wrong....
camlex is offline
post #10 of 30 Old 11-26-2008, 12:01 AM
the critic's Avatar
Quoted: 2 Post(s)
The first number (0,5,10, 15, etc) is an empirical number that tells you how well the lubricant will flow at low temperatures. The numbers are assigned based on standards listed on the SAE J300 chart.
The second number, W, means that the oil is suitable for winter use.
The third number (20, 30, 40, etc) refers to the lubricant's kinematic viscosity at 100C according to the SAE J300 chart once again.
You should use the OEM recommended viscosity. Unless you are using your vehicle for operating conditions that the vehicle was not originally intended for (constant racing, auto-x, etc), then the OEM recommended oil grade will do a great job of protecting your vehicle.
the critic is offline
post #11 of 30 Old 11-26-2008, 12:02 AM
LOV
268 HP OWNER
LOV's Avatar
Quoted: 0 Post(s)
The TSB does say as a contradiction, that the recommended grade on your engine cap or in your Owners Manual shoild be used.
Even better answer to OPs question
LOV is offline
post #12 of 30 Old 11-26-2008, 12:55 AM
Quoted: 0 Post(s)
6th gen i4 camry suggests 5W-20. As stated on your oil cap. And I use Castrol Synthetic all the time.
2007 Super white Camry CE
JL 13w7 in Prowedge box/Hifonics Brutus 1600rms
HID 8k and SE mesh grille
Fobanginvtek is offline
post #13 of 30 Old 11-26-2008, 04:18 PM Thread Starter
Quoted: 12 Post(s)
(Thread Starter)
Thank you for inputs.
I bought Castrol Synthetic Blend 5W20. with toyota filter.
After 36,000 may be 5W30...........
camlex is offline
post #14 of 30 Old 11-26-2008, 07:53 PM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
OP, you are in Houston. Right now I'd say that 5w20 or 5w30 would be just fine. If it gets to be late June, early July and you drive across town or worse every day, then I'd say that 10w30 would be just fine and keep you through September. 0w20 might reduce splash resistance inside the engine but I can't imagine it is going to improve the longevity of the engine in hotter climates. Use 0w20 in Reno or Omaha in January.
gdanaher is offline
post #15 of 30 Old 12-03-2008, 10:49 AM Thread Starter
Quoted: 12 Post(s)
(Thread Starter)
To cover by warrenty i decided to go with 5W20 till 36,000
Thanks,
camlex is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
Back
