2002 camry 4cyl coolant help - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 03-19-2009, 10:16 AM Thread Starter
Senior TN Member
bronzemaxell's Avatar
Quoted: 13 Post(s)
(Thread Starter)
this probably has been discussed many times.
i am thinking to flush the coolant on my 2002 camry 4cyl LE, 115k miles, vin# begins with JT, the coolant color now is between red and orange, i don't know when coolant was last flushed.
i also have a 2003 camry SE 4cyl stick shift that i bought brand new 6 years ago, vin# also begins with JT, and came with pink coolant from mfg, and i have not flush it yet.
i am little confused about the coolant color, 2002 camry 4cyl and 2003 camry 4cyl seem to have the same engine, does the 2002 4cyl use pink or red coolant?
bronzemaxell is offline
post #2 of 5 Old 03-19-2009, 11:48 AM
Senior TN Member
Quoted: 1 Post(s)
it you are doing a full collant flush then the color don't matter since all the old coolant is not going be in the cooling system anymore. if you are getting the red coolant, you will need to mix with with water 50/50, the pink you will not need to mix.
LoudCamry is offline
post #3 of 5 Old 03-19-2009, 12:01 PM
2004 Camry LE
somick's Avatar
Quoted: 37 Post(s)
As far as I remember Toyota switched to a new type of coolant in 2004. I believe it is called Superlife or something like that and it is fully compatible with other coolants Toyota has used before.
Just do flush and fill.
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline
post #4 of 5 Old 03-19-2009, 09:01 PM
carlo$'s Avatar
Quoted: 0 Post(s)
look @ my site for your answer.
2005 LE 4 cyl
carlo$ is offline
post #5 of 5 Old 03-20-2009, 12:17 AM
2002 Camry
ToyotaToday's Avatar
Quoted: 0 Post(s)
Sam
I bought some coolant for my 2002 today and it is longlife. Apparently for 2006 and above its extended longlife (or something like that), so it depends on your car.
2006 4Runner Limited
ToyotaToday is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
Back
