2003 Camry Headlights Keep Burning Out - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 11-22-2010, 03:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
So the headlights on my 2003 Camry keep burning out.
It happens intermitently, one will burn out, I replace the bulb and then the other one burns out.
At one point, I put a bulb in and it lasted only 2 days.
When one of the bulbs burned out, I went to go take it out and as I jiggled the wire harness, it lit up again.
A little info.
-Both headlight housings are BRAND NEW.
-The actual bulbs were never touched by any hands since that could burn it out very easily.
Any hunch on what this could be?
Let me know if you need any more info?
Thanks in advance.
Joel930 is offline
post #2 of 6 Old 11-22-2010, 09:21 PM
Goes Against The Grain
Punks_Not_Dead5's Avatar
Quoted: 18 Post(s)
iTrader Score: 8 reviews
are they aftermarket headlights? from ebay? Because they're notorious for burning bulbs fast. i went through a few sets myself. But i always got replacements free cause the store i bought them from had a 1 year warranty.
But i got tired of it and put my OEM lights back in. You may just need a new wiring harness, if you jiggle it and the come back on, could be a loose conection
2002 Camry SE TRD Supercharged 1MZ-FE "Snow White" - Track/Summer Car
2010 Rav4 Limited 4WD - Winter Car
1998 Subaru Legacy 2.5GT Limited - Sold
Toronto/Canadian Meets and Track Days - http://www.toyotanation.com/forum/69-canada/
Punks_Not_Dead5 is offline
post #3 of 6 Old 11-22-2010, 09:50 PM
Low & Slow Cam
BlackCam09's Avatar
Quoted: 6 Post(s)
strange my mom's 02 camry does the same thing, sometimes it will work for months and then intermittently stop working and we move the harness around like you said and it comes back on.....
BlackCam09 is offline
post #4 of 6 Old 11-22-2010, 10:42 PM
cardsfanpb's Avatar
Quoted: 0 Post(s)
go to O'reilly and get package of bulb grease for $2.
i used to have the same problem with my tails. Smear it all over the connection and it should do the trick.
-Preston
'07 Camry SE V6
cardsfanpb is offline
post #5 of 6 Old 11-23-2010, 01:30 AM
Quoted: 1 Post(s)
or dielectric grease, which is probably the same thing as the bulb grease
CamrySExxx is offline
post #6 of 6 Old 11-23-2010, 09:18 AM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
Look at the plug that connects the bulb and verify the metal is clean and shiney. If not, replace the connector. Oxidation can cause resistance and heat. Heat kills bulbs. Make sure the bulb actually failed and not the harness. Use your ohm meter to check for continuity between the connector spades.
gdanaher is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
Back
