P420 Code What should I do first????? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008) Toyota Camry Discussion for years 2002-2006 & 2007-2011, as well as Solara Discussion for years 2004-2008. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 7 Old 03-24-2011, 08:06 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 2002 Toyota Camry with 185k miles. The check engine light is on with the code p420 for inefficiency with the cat. converter. The converter has already been changed once before. What I want to know is if I clean the MAF and the o2 sensor would that be the cause of the code. As well it has a rattling noise by the converter and I take it that it needs to be changed and the reason its bad is that the o2 sensors have never been changed. Any thoughts?????
jullissia is offline
post #2 of 7 Old 03-24-2011, 11:51 AM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
Cleaning the MAF is something that likely needs to be done anyway but I doubt it will solve the problem. The error is likely being generated by the O2 sensor at the cat. Either the cat is toasted again and the sensor is right, or the sensor is old and needs to be replaced. Since the sensor is relatively inexpensive I would change it first if you are just tossing money at it. Again, since it hasn't been replaced before and is near its end of life it wouldn't hurt. If the problem clears then all is well for awhile. If not then you need a new cat, but you were guessing that anyway.
Just be aware that at this mileage the vehicle is near its EOL so be careful what you do here. Perhaps a junk yard cat this time. Try to avoid spending much because you aren't going to see the value. At this age, bad things start to happen.
In another thread, some schmuck just bought an old Camry with 166k miles and paid top dollar because it had been cleaned up. With mileage like that the thing becomes a money pit. Good luck with yours though--you have likely driven your money's worth out of it!!
gdanaher is offline
post #3 of 7 Old 03-24-2011, 02:23 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Well I just took to a shop and they said that nothing is wrong with converter.
post #4 of 7 Old 03-27-2011, 01:08 PM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
So, what did they tell you WAS wrong with the car?? The idiot lights don't come just because it is the holiday season.
gdanaher is offline
post #5 of 7 Old 04-05-2011, 09:09 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
It needed a new converter and fuel injector cleaned
post #6 of 7 Old 04-05-2011, 10:17 AM
Quoted: 0 Post(s)
Sounds like a recommendation from an untrained idiot, aka UTI. I suggest looking around on the web about p0420 bc a lot of ppl replace their converter and nothing.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline
post #7 of 7 Old 04-05-2011, 05:01 PM
Toyota Parts since 1981
Quoted: 2 Post(s)
We have never had a car come into the shop with a code P0420 that a correct catalytic converter didn't solve. I say correct converter because some people change the wrong converter on multiple converter systems and of course it doesn't help. Any converters past the last oxygen sensor are not monitored and will not put out a P0420 light.
06 Avalon XLS
TRD drop-in air filter
TRD rear sway bar
KYB Touring Struts
DOHCammer is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 5th & 6th Gen (2002-2006 & 2007-2011)/2nd Gen Solara (2004-2008)
User Tag List
Linear Mode Linear Mode
Back
