I have a 2005 XLE 4 cyl with 68K miles and a few weeks ago noticed the start of something odd... As the car goes from what appears to be 3-4th gear about 30 mph, there is a push in the rpm about 2-300 and then it shifts. It is not a hard shift, nor does it occur every time. Havent correlated it to first ride of the morning or increased based on being warm etc. Ive had no DTC codes. About 6K ago had transmission fluid flushed, front axles, ball joints, wheel bears, struts and hubs were replaced due to one side failing. Yesterday I brought it into the dealer and they were unable to reproduce. Only thing they found was ABS sensor codes- tested the sensors and found them to be working... Oddly enough, my wife mentioned a flashing brake light a few times when she drove the car recently(I drive it usually and have not seen such.)She is not a good historian so I cant find out if it was abs or brake light.
Transmission fluid is full, looks jut like when it was put in, without any metal shavings.
I purchased a sub for alldata and there are no tsb's for this vehicle that relate to anything like this.
So, any ideas about what may be the issue. Is it possible that there is an issue with these sensors causing this shifting symptom?
Thanks for the input.
