Hello, recently I just installed Rosen Navi G2 in my 2007 camry but dash light button lit up after I turned my engine on like 5 secs and it just turned off itself. I tried to messing around with Navi settings and couldn't find the solution. I wonder if anybody could help me or have this unit came across same problem like me. Any inputs would be appreciated. Thanks!
Thanks Glenn! Really appreciated your help!! I will give it a try on the weekend and reconnect all harness wires and will see if it work or not. BTW..I'm from MASS too...lol
I don't think you will have to check your harness, headunit lights up blue when you put your headlights on and if you push on the screen under the binoculars on the left side you will see a quarter moom logo, press onyour screen there and it will light up green, you can try this tonight. I went out and checked mine and its a seetings thing instead of a harness. BTW what part of Mass are you in ????
O.K. I see that what I tried did not work for you, you can call Rosen Customer service and they maybe can walk you through some things.
Their number is 888-883-2970. So your from Randloph, my Sister lived in Winthrop, then Lynn. So your on the south side of Boston, I am near Worcester.
Glenn
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
586.9K members
Since 2001
