My rear brake makes a whining noise when I go on reverse. I know is brake related because while on reverse, if I barely touch the brake pedal the noise goes away. But without touching the brake pedal whines and sometimes loud and is embarrassing. Anyone knows if this is an adjustment problem or what should I look for?
Updated rear disc brake pad support plates (fitting kit) are available to improve this condition. It was covered under 3yr/36000 mile warranty. If your VIN is before these, then it applied to you. This may not be your problem though. You may just have rust or corrosion and need an adjustment. Have you checked the rear pads? 4 cyl 4T1BE46K#7U065422 4-cyl.4T1BE46K#7U579910 Camry V6 4T1BK46K#7U017837 4T1BK46K#7U520540 4-cyl. JTNBE46K#73036518
i havent check the brake yet and i wouldnt even know what to check for.. i doubt is under warranty as my car has 152.000 on the clock. i know basics mechanics but not much so would need a link to the kit i need or some pics on how to check it. on a related note i have maintnance records from when i bought the car and it shows that the rear brake pads were changed in november of 2011
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
586.9K members
Since 2001
