My check engine & VSC lights came up one fine morning. The obd scanner showed only the gas cap open code but not the VSC. I checked and sure enough, the gas cap was not fully closed.
The VSC was defeated and not working (I checked by doing some hard accelerations on slippery surfaces and that "chatter" was not there, letting the wheels spin crazy) but the scanner didn't show anything for it. My search revealed for the VSC light the yaw sensor might be off calibration and a dealer should be able to fix that. Anyways.
I closed the gas cap properly and didn't reset the check engine light from the scanner. I wanted to see how many miles would it take to reset that light on its own. It turned out that after around 225 miles of closing the gas cap properly, when I parked the car overnight, the next morning both the check engine & VSC lights were gone. I was surprised to see the VSC gone too.
I immediately did a few hard accelerations on slippery surfaces and sure enough the VSC was working. From this I gather, that the check engine light made the VSC come on and when it went off, so did the VSC. I will do this whole exercise again by leaving the gas cap open to establish:
1. How many miles does it take for the open gas cap to trigger the check engine light
2. Does it take around 225 miles to reset that light on its own
3. Does the VSC light come on with the check engine light and defeat the VSC
This all episode happened when I was almost at 30k miles and during these lights coming and going, the Maintenance Required light didn't come!
I was wondering if anyone else has experienced this.
Thanks
Thanks
