I have 5k morimoto HID headlights, and I'll be buying morimoto fogs in about 3 weeks,
The fogs will mostly be for looks, but if the need arises, I'd like them to perform adequately. We don't live in a rural area and mostly travel on lighted roads/ freeways. These will be HID's, so if I use a lower color temp they won't give the housing a yellow tint when they're off.
I am leaning toward getting 5k's to match but I'd like to hear your opinions. I know I'll at least get one or two "hid fogs are lame"
I would use 3000K color temperature for the fog. It depends on your personal preference. To me, 4300K or 5000K low beam and 3000K fog look good. There are inconsistent ideas about selective yellow vs white colors for fog, but people "perceive" yellow better than white in foggy condition.
i personally have 15000k's in mine which is almost blue blue but not quite, i have them both in the regualr beams and high beams and i have to say i live in the country and driving down those back roads with those on is sexy looking so i would absolutly love to get some hid fog lamps but im not willing to spend 300 or 400 for them
If it is really 15000K, it's going to be purple. The output for a 15000K HID is less than halogen. I hope it's a joke when you have 15000K in both your low and high beam.
Nope that's how it is and its more blue than purple really dont hate bro i mean we all ahve our different likes and dislikes so i mean its cool I like what I like!!!!!
no hate but literally rofl at 15000k, the higher you go the lesser lumens you are getting which is pointless for driving since it will be just for color.
But for me driving int he dark country it doesnt matter bc it pitch damn black dark too lol so i can see everything perfectly fine at night now i agree int he city it is kinda hard but its so lit up even at night to be honest you really dont need them lol once you get used to driving with them you honestly can see alot more than you think
No i have two seperate sets of headlights thank the lord the cheaper that way lol but VVME.com does sell HID lamps with high's and low's together so i believe finding them wouldnt be a problem if you were wanting some.
Not sure about the retrofitted projectors in foglights (I think eyezack87 had ES300 foglights retro'd, not sure if those are projectors either, but try searching), but for sure the 3000k will perform best in fog.
yes it will be sweet that your fogs match your low beams, but i dont think its very practical, due to the fact that
the white light will reflect and have a negative effect. plus, fogs are usually white anyway, so imagine shining a white light onto a white fog cloud. it doesnt work out well, i can attest.
i remember reading somewhere that the yellow light will penetrate the fog better and it's easier for u to pick up the visibility due to the yellow light. again, when i switched from 5000k to 3000k halogen foglights, that is true (imo)
HID or halogen 3000ks, i can't say, which one you will have more luck with the in the fog.
also might blind other drivers via HIDs in fogs.
but just thinking about it, if you had something that's too bright it may end up being a negative in the fog due to reflection off the water beads.
that's just my 2cents worth of analyzing the situation, still should try to research it online.(google)
i think you should first try driving with 3k halogen fogs. that way if you dont like it then you should spend the money and do the fog retrofit. on my rav4 i was going to do hid fogs in the reflector fogs and i knew i was going to do 3k yellow bulbs. so before anything i simply changed the stock bulb for a yellow halogen bulb. and ive been driving with that since then. they do a great difference compared to the stock bulb.
Okay, I promise I'll slow down.
You didn't comment on how the projectors (with hid's? performed). Is the retrofit worth it, or should I just get some yellow halogens?
Sent from my Autoguide iPhone app
google search ES300 foglights and you might find the answer to what you are looking for in terms of if its worth it to retrofit.
i'm not a retrofit guru so i can't tell you where to begin to search how to retro a ES300 projectors into your foglights, but hopefully some searching can help you decide.
also, try to refrain from using HIDs in non-projector foglights, they do tend to blind people and cause glare..or worse.
Excellent information. Thank you everyone, I do feel this has been a great discussion. I guess for potential write ups that fit my application I'll refer to - :google: and quit bothering you all
Well, maybe I'll ry some MTEC 3000k's and see how it works out. It will be MUCH cheaper than a retro, but maybe some part of me is just looking for a project (which I will spend money on.) They're always much more fulfilling when they're justifiable. I'll need to search to see if I will get better performance out of HID fogs (through a projector with a cutoff) without blinding anyone or just super illuminating the water particles in front of me.
But I did want to try out my first retrofit, and the headlights are too expensive to screw up ..:boink:
The Toyota fog housing (the camry, venza, and highlander use the same housing) uses a bulb with a painted glare tip to prevent glare. The HID bulb won't have that and you will basically have 2 high beam's on the front corners of the bumper when they are on. I know because I used to use them before I learned the error of my ways
If you want hid fogs, projector retrofit is the way to go. You will get better ouput and won't blind oncoming traffic.
They have actually stopped selling blazer because it was total shit... I retrofitted my fogs with the blazers, but had to remove them due to damage. The blazers couldn't handle 35 watts of HID's without melting/bubbling the "chrome" off the bowl and making them totally useless. I would stay away from blazers at all cost.
as mentioned other good fogs: lexus ES, ford fusion, Hella Micro DE, or the morimoto matchbox (from TRS). I saw you mentioned the Morimoto mini, I don't think you could fit that into the housing without extending it with pvc pipe or something.
The fogs in my car are the same as the camry's, some Lexus' and rav 4's (there are other Toyota's I'm sure). Does anyone know of a write up, or someone who has retroed their fogs?
Thanks for correcting me about Blazer fog. I only know some projectors that people usually retrofit for their fog light but don't want to do it because I don't think I will need it.
Yeah, they only removed them in the past month or 2, so its a pretty recent change. I can say I won't re-retrofit my fogs though, HID headlights put out enough light its not necessary. With HID fogs, you get too much light output in front of the car, killing your distance vision.
It looks like the color is white 5000k. I would like to have the color in yellow. What other opinion do I have? or it is better just keep the original ones..thanks
imo if you are willing to spend $100 on some aftermarket bulbs, you are better spend $170 and get a set of decent real LED fog lights from a company that started "HID rush" in US and has solid "A" rating in retrofitting community. https://www.theretrofitsource.com/complete-housings/fog-lights.html
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
586.9K members
Since 2001
