I was driving normally and all the above lights came on at once. Car is an '06 Solara convertible and is well maintained with all fluids recently changed. I am thinking it is the computer control that may have burned a chip or something.
Any ideas before I squander a fortune at the dealer?
try resetting the ecu or pulling the battery to see if the lights go away first
occasionally, ecu's can have a "hiccup" and set of warning lights for no reason ( at least occasionally on some of the older toyotas).
If the light comes back, get your CEL checked to see what code it is. If it's setting off your VSC as well as your traction control, it may be a transmission solenoid code. Back in the day, my 00 solara had an intermittent issue with one of the tranny solenoids and when it came on, the traction control will then also be turned off. They didn't have VSC back then, but otherwise, I'm sure that it would have probably come on too if it had
Thank you, Ill let you know the results. We had a very bad thunderstorm with lots of lightning and I think this might have had something to do with it.
