One of the bolts on my air filter housing is missing and I need to replace it. Anyone know if they make that part? The dealership wants me to replace the entire housing for $400....fat chance. I have a 2007 Camry se. I don't care if I have to just go to home depot and buy a bolt there. Thanks for any help.
+100
use square nut for bottom portion of the housing. glue it in place if you missing nut or use two small nails (just drive them into housing beneath the nut). use bolt with washer for top portion of the housing.
toyota overstock.com has these bolts they are less than 1.00 ,but you have to pay ups shipping usually about 11.00 and up,so if you order order other parts you may need
The bottom nut should just snap into place when you insert it with the nipple side up. Mine did anyway. Mine fell out when they replaced the air filter and pushed the top bolt too hard and the nut just fell out. So I found this one for a replacement:
