How to remove baked egg on roof? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2006, 04:02 PM   #1 (permalink)
View joesixpack's Photo Gallery
My car was hit with raw eggs at work today. Now the eggs have baked on the car sitting in the sun all day. My question is what is the best way to clean the baked eggs off the car? I went to a carwash to spray it off without much luck. Don't want to scratch the finish and I am not sure what will work safely on the clear coat finish.
Help???
J6P in RI
joesixpack is offline   Reply With Quote
Old 09-12-2006, 11:50 PM   #2 (permalink)
View faldoc's Photo Gallery
Help???
J6P in RI
I would put cold wet rags on it for several hours and gently scrape it off as it softens. Let us know how it goes...
faldoc is offline   Reply With Quote
Old 09-12-2006, 11:54 PM   #3 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $483968
View prnc_chrmng's Photo Gallery
use bacon.
or your can try goop off. altho i would read the directions and what not first to see if it would affect the finish. or maybe a claybar
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 09-13-2006, 02:24 PM   #4 (permalink)
View jiannone's Photo Gallery
Soaking it sounds like a good idea. Also, Meguiars makes a very nice paint cleaner after you get the initial big clumps off. A clay bar may be helpful for the smaller stuff.
jiannone is offline   Reply With Quote
Old 09-13-2006, 03:34 PM   #5 (permalink)
View toyomoho's Photo Gallery
As faldoc states, get it wet and keep it wet. Then gentle remove it, use soap and more water. Much like cleaning a frying pan, but you don’t want to scrape this pan to hard. Egg can stain the paint, do it ASAP.
Old 09-13-2006, 04:26 PM   #6 (permalink)
FlopShot's Avatar
View FlopShot's Photo Gallery
There is a car cleaner aerosol called Tarminator. It costs about $3.99 at WalMart, and $5.99 at auto parts stores. This stuff takes off everything right down to the clearcoat. It's great for all kinds of stuff, like tar, bugs, etc. For really bad stuff, you can spray the Tarminator directly on the affected area and let it soak for a couple of minutes. You will have to re-wax the area after using it. As mentioned, egg may stain all the way thru paint, so clean it immediately.
FlopShot is offline   Reply With Quote
Old 10-13-2006, 04:55 PM   #7 (permalink)
FJ nut
View RAV4EVR's Photo Gallery
Why didn't u just eat it ?
The bug/tar removal spray at auto Zone works.
***** My love.... My dream.
RAV4EVR is offline   Reply With Quote
Old 10-15-2006, 04:04 PM   #8 (permalink)
2011 BMW 535xi M-Sport
pillpusher84's Avatar
View pillpusher84's Photo Gallery
Help???
J6P in RI
Well, the best thing would have been to get it off of the car immediately, since your clear coat has probably cracked from the egg anyway, this would have avoided less damage.
Since you were unable to remove immediately, the best thing to do would use some type of bug/tar removal, let it soak, & gently "scrub" with a wet microfiber towel. Once you get all the egg off, wash the entire car. Then clay bar the area(s) that were hit with egg & wax afterwards.
If there are still small scratches / "cracks" in the clearcoat, then the damage is permanent!
pillpusher84 is offline   Reply With Quote
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 164 11-10-2011 07:40 AM
How to remove a headlight Gen 3 YESCA 3rd & 4th Generation (1992–1996 & 1997–2001) 26 04-29-2010 07:51 AM
dashboard & front seats Midnight87 Supra Forum 6 07-09-2006 06:09 PM
How-To Sunroof Fix for '90 Camry (long) 1966CL77 General Discussion 0 11-03-2004 10:16 AM
How To Remove AE86 Sunroof? 86B Archived Corolla threads 5 04-27-2003 10:33 PM
