2 quick questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2006, 01:31 PM   #1 (permalink)
View REV800X's Photo Gallery
2 quick questions
Hi, I'm a new owner of a TCH, and have a couple of quick questions.
If I happen to have the car outside this winter on a 40 below night, what happens if I start the car to warm it up, and go inside with the "key"? Will the ICE run as needed to keep the charge up and warm the car up? Or with the key not in the vehicle, will the security system prevent the ICE / hybrid components from running normally?
Also, it may have been on a different forum, but thought I had read about others with a squeek in the center console - along with method to resolve?
Thanks!
REV800X is offline   Reply With Quote
Old 10-25-2006, 02:38 PM   #2 (permalink)
FlopShot's Avatar
View FlopShot's Photo Gallery
Thanks!
Once you start the car as normal, if you leave the car with the key fob in your pocket, the ICE will continue to run. In fact, the entire car remains on completely, not just the ICE. This can be a problem if you are running only on battery. That is why the car will beep at you a few times to remind you that the car is still on.
As far as the center console squeek, the self-fix is discussed here in ToyotaNation in the Gen5/6 forum (because this is not a TCH specific proglem, it is with all 2007 Camry), and also on the GreenHybrid forum.
FlopShot is offline   Reply With Quote
Old 10-26-2006, 03:06 PM   #3 (permalink)
TMS Prius Expert
Tideland Prius's Avatar
View Tideland Prius's Photo Gallery
Just remember to lock the car with the mechanical key otherwise someone can hop in and drive away.
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
Tideland Prius is offline   Reply With Quote
Old 10-26-2006, 04:05 PM   #4 (permalink)
View PhantomZX's Photo Gallery
So the car lets you drive any distance without the key fob as long as it's on?
PhantomZX is offline   Reply With Quote
Old 10-26-2006, 05:05 PM   #5 (permalink)
utkan's Avatar
View utkan's Photo Gallery
yes it does till you shut it down yourself.
2007 Camry HYBRID Magnetic Gray Metallic ((I got a Hybrid And I am Not Afraid to use it.))
2005 Dodge Caravan SXT
utkan is offline   Reply With Quote
Old 10-28-2006, 08:14 PM   #6 (permalink)
USA
Thanks for the replys. I do have a "black" one as well, althought not as unusual as first thought...
Thanks.
Quick Alarm Questions thapranksta 5th & 6th Generation (2002-2006 & 2007-2011) 1 09-21-2006 08:42 AM
Three Quick Questions Turn 180 3rd & 4th Generation (1992–1996 & 1997–2001) 5 07-27-2006 09:29 AM
Just some quick questions!!! patricklong Tercel, Paseo, Starlet, and Sera Forum 3 03-24-2006 05:05 AM
few quick questions.... 91_CorollaWagon Archived Corolla threads 11 03-18-2006 01:50 AM
Mud Flap Removal Quick Questions? turbos17 2nd Generation (2005+) 7 03-06-2006 07:50 PM
