Originally Posted by fueltesters
Many people wrongly believe it's the major gas refineries (E.G. Shell, Mobil, Sunoco, etc.) who blend in ethanol, with the other hundreds of other ingredients gasoline contains - This is not true-
Plus, gas at the refinery level must go through extensive testing before being released - gas at the distributor level (after blending in ethanol) does not.
This helps to explain why you will find a wide variation of alcohol % at pumps, including ocassionally over the legal limit of 10%.
Reason ethanol not added at refinery: Ethanol is hygroscopic (readily attracts and absorbs water) and too high a risk for water contamination if sent through underground pipelines.
GeorgiaHybrid: In reviewing your responses to others, I get the feeling you simply have lots of free time, and enjoy useless debates/arguments.
I'll respond to you once - and next time you wish to waste my time it will be at my usual and customary hourly consultant fee.
(For everyone else, feel free to ask me any questions and I would be happy to answer them as often as I can, obviously for free).
As per my post, see quote above I stated ethanol is
not added at refinery due to risk of water absorption...I never said there were not other reasons - and who cares anyway?
I was simply trying to help others to understand that ethanol blending is NOT at branded gas refinery, and primary explanation for distributors varying and (all too often) illegal, over 10% blending found at some pumps-
In simple words, "No regulating or gov't agency is routinely testing or monitoring that gas at pumps contains correct and legal amt. of ethanol".
Gas stations owners, not consumers, should be required by law to assure gas contains legal limit of ethanol...
They're not.
Every state should have the same exact laws regarding E10 -
They don't.
E.G. Some states require pump labeling, some don't, some require pump labeling when over 1, 2 or other percent...
Some states now require 10% ethanol in ALL grades of gas...Some states allow premium to be ethanol-free, most do not...and on and on...
- Very confusing for your typical consumer and for me too -
The state fuel laws change so rapidly (sometimes weekly/monthly) I can't keep up with them.
Next- You're accussatory, insulting remarks...
I would quote your full response to me, but I don't approve of your language.
You, (Georgia Hybrid) said, "I do know a little about the business and realize that you are in the business of selling a product...".
Wrong, my primary business/background is as a consultant...not a retail product business.
(Fuel-Testers is a division of MLR Solutions).
And regarding product deception, why don't you check out all the useless "ethanol fixing" fuel additives and gas treatment products that are booming.
(and leave me alone).
Of course, as an experienced educator for ethanol, these companies contact me almost everyday to "support" and "promote" their often useless and expensive products... I don't.
But, I may be forced too, if I keep wasting my time responding to people like you. (just kidding).
Some additives are useful, some are harmful, but none always prevent phase seperation/water contamination of E10 gasoline...but people waste money anyway thinking they will completely protect their engine from E10 - They won't.
Simple no-cost "necessary precautions" offer the best protection -
(See website or email me for copy)
Reusable, inexpensive portable alcohol test kits are useful for anyone wanting to do everything possible to protect their engines and/or avoid alcohol-blends of fuel.
5 years ago I thought need for test kits would be few years at most - instead
gasoline laws became less consumer-friendly, E10 distribution rapidly increased throughout the U.S. and sales increased at an unbelievable rate (Sales doubled this past month).
Test kit we distribute uses only about 1 Tablespoon of fuel (18 cc) -
Test kit is alcohol resistant, weighs only 5 ounces, has raised non-ink permanent markings, rubber seal for transport/saving specimen...etc,
Your suggestion wastes 100 ml of costly fuel, relies on ink markings which will wear off with 1 or 2 uses (alcohol's a strong solvent/cleanser)...etc.
If you can't afford $15.00 to $25.00 for a product you can resuse over and over for years, evertime you fill-up, it's safe to assume you can't afford gas to drive your car either. (So why would I even want to "market" it to someone like you?).
And before you try again to misrepresent something I've said,
for the record:
1. I do not support e10 as a fuel(does little to decrease our petroleum consumption and has several damaging effects/risks to many engines, etc.).
2. I do believe ethanol is useful for oxygenation, where indicated (replacing MTBE) for now.
3. I do support E85 use in flex-fuel vehicles to decrease our dependence on petroleum imports, until a better alternative/renewable fuel is in the market (e.g. hydro, solar, wind power).
4. I do not believe E85 gas is a long term solution (but it is the replacemnt for petroleum we have right now).
I think it's a real shame that both our state and federal governements (mandating ethanol gas) have done almost nothing to educate the public on how to properly manage alcohol fuels.
Hoped my comments would be useful here - but really do not have time for the direction you (GeorgiaHybrid) keep going in.
People need useful explanations and practical facts and suggestions on how to safely manage e10 gas,
not hours of debate/discussion on irrelevant ideas, suchas "exactly" how gas travels through pipelines or detailed scientific computations on absorption or adsorption of ethanol and water.
Quote, Georgia Hybrid said,
"1) Ethanol can not be added at the refinery due to several reasons. The main one is that gas is transported in pipelines with other petroleum products. The method to keep them separate in the pipeline is to use a water "slug" between shipments. The ethanol will mix with these with bad results for all of us buying the fuel oil, diesel, gasoline, kerosene, etc. coming thru the lines..."
My response: Who cares about 'slugs' - Public needs to know things such as :
Ethanol has an amazing ability to attract and absorb huge quantities of water into gasoline - There's moisture underground.
E10 has a short shelf life (months)- Is fresher when blended locally...
Conventional gas stayed stable for years...
Distributors blending can be inaaccurate...E10 Gas Pump labeling can be unreliable...etc.
End of story.
Good Night -
