Has anyone tried installing a rear view camera to their Toyota Camry Hybrid (TCH)? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2008, 11:18 PM   #1 (permalink)
View t1t0 LuX's Photo Gallery
Hey Y'all, I have a 2009 Toyota Camry Hybrid with the nav option. Unfortunately, the only car Toyota makes with a back-up camera is the Prius. Has anyone out there successfully installed a camera so that it will show up on the nav screen? Or has anyone installed a rear view camera in a TCh period? Any advice and help would be awesome.
t1t0 LuX is offline   Reply With Quote
Old 06-02-2008, 10:02 PM   #2 (permalink)
TMS Prius Expert
Tideland Prius's Avatar
View Tideland Prius's Photo Gallery
check greenhybrid.com. There's a DIY + pics thread on installing the backup camera.
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
Tideland Prius is offline   Reply With Quote
Old 06-06-2008, 10:54 AM   #3 (permalink)
Still lovin my Hybrid
View honest_abe's Photo Gallery
It is not clear as to whether the discussion on connecting to the NAV unit itself is still the same. My TCH has a newer model NAV than the one used by the initiator of that discussion and I have yet to find out w/o ripping uot the unit first if the connection will be the same.
My '09 has
86120-06460 (Toyota number)
DW468100-0336 (mfgr number)
honest_abe is offline   Reply With Quote
Old 06-06-2008, 12:49 PM   #4 (permalink)
tharvey's Avatar
View tharvey's Photo Gallery
near the end a person reports connecting a camera to a 2009
tharvey is offline   Reply With Quote
Old 06-06-2008, 07:19 PM   #5 (permalink)
TMS Prius Expert
My '09 has
not sure why the screen part number should be different. (I mean there's an XLE one and a Hybrid one...)
Old 06-06-2008, 09:17 PM   #6 (permalink)
tharvey's Avatar
I copied and pasted this from the other forum
04-28-2008, 05:38 AM
jeffgl21
Enthusiast
Real Name: Jeff
Hybrids: Toyota Camry Hybrid
Re: Back up Camrea installation to the NAV unt (with pictures)
I just installed the BEC106 on my 2009 TCH. Removal of the radio and console were easy thanks to Jbagri and others on this thread. Some additonal comments based on my experience:
When removing the radio, temporarily re-install the shift handle which acts as a soft stand while you are pulling the unit out of the dash.
Apply blue painters tape around the edges of the radio to help prevent nicks if the radio gets bumpted during removal.
I removed all the connectors behind the unit in order to maximize as much access to the R10 connector. They're mostly color coded and were fairly easy to remove and re-install.
I had no luck with the CD audio cable. Pins were too small so they didn't lock in, and, the wires were too soft.
Instead, I purchased a female DB25 connector kit from Radio shack. It includes the DB25 shell (not needed) and 25 female pin 'crimp' style connectors.
I also used telco wire which is stiffer and figured would help with the insertion into the R10.
I soldered the ends of the telco wires into each of 4 DB25 female pins.
Now the tricky part - make sure your solder joint is clean and minimal. Remove any blobs with a file. Further, the center of the DB25 pin has a small bulge and will not fit through the connector, that too will need to be filed down around all sides. I broke a number of pins in this attempt, but you have 25 chances to make it perfect. Take your time with this and be patient. You don't need to remove much - a millimeter or so will suffice.
I then soldered the telco wires to the BEC106 cable and applied wire tape.
During the insertion, I used a Sub-D insert/extract tool (also from Radio Shack) to help push the wire down into the connector.
I reconnected all the other cables and re-installed the radio. The camera came to life when I put the car in reverse. During this install I also installed an Ipod integration module. See the Ipod thread, works very nice as well.
Many thanks to all who contributed to this thread, I would not have attempted to do this otherwise.
I hope this works as I will be doing the same on my 2009 canadian hybrid camry in the next week. I will however be dismantling the trunk and attempt to mount the camera under the plate over the licence plate which is quite simular to the way the prius has it mounted.
It will require some measuring and cuting of this plate and hopefully the camera will sit under the plate with a small opening cut out for it to see on a 45 degree angle, which will be almost identical to the prius camera mounting.
tim
Old 06-06-2008, 09:59 PM   #7 (permalink)
View carolinacamry's Photo Gallery
All that sounds complicated. I just bought a wireless camera on ebay. Camera connects to the backup lights and mounts onto the licenses plate. Monitor gets power from the power source on the console. Only costs me $60.
http://img501.imageshack.us/img501/706/1004578sw7.jpg
carolinacamry is offline   Reply With Quote
Old 06-07-2008, 08:07 PM   #8 (permalink)
View runutzzzzz's Photo Gallery
It's not that difficult, I jsut did it in my 09 TCH. Take it to your local mobile audio installer to have it installed. The Wireless cameras sux plus it looks silly.
runutzzzzz is offline   Reply With Quote
Old 06-16-2008, 04:36 PM   #9 (permalink)
View DRod's Photo Gallery
Actually, my '08 Highlander has a backup camera. And it's actually very clear. I wonder if that would work. It displays in a smaller screen than the GPS.
DRod is offline   Reply With Quote
Old 06-16-2008, 07:22 PM   #10 (permalink)
it is what it is
akira751's Avatar
View akira751's Photo Gallery
Gen6
Also with the nav its a bigger screen than the Prius. The Tundra has a back up camera and the 09 Tacoma and the new Sequoia.
We install TCH back up cameras all the time. Check with your local dealership
07 Camry SE V6, Nav Mag Grey,18" Nex-0 gun metal, Trd Springs,K&N Typhoon Intake
http://www.cardomain.com/ride/2475669
akira751 is offline   Reply With Quote
Old 06-25-2008, 01:59 PM   #11 (permalink)
View tomrhoades's Photo Gallery
I just had a hear view camera installed, works great, total cost $300 with other camers.
The unit I had installed was the following - http://search.store.yahoo.com/cgi-bin/nsearch?catalog=electronman&query=250-8076&.autodone=http%3A%2F%2Fwww.mnrelectronics.com %2Fnsearch.html
And I went with this camera instead of what came in the kit - http://www.millionbuy.com/exoexr900b.html
I got a great deal...
Tom
tom@rhoades.us
tomrhoades is offline   Reply With Quote
Old 06-25-2008, 09:09 PM   #12 (permalink)
tharvey's Avatar
Tom
tom@rhoades.us
Can you tell me did the harness which came with the kit was it plug and play or did you find yourself attempting to place the little pins into the original connector
thanks
tim
Old 07-27-2010, 02:22 PM   #13 (permalink)
View Sign Guy's Photo Gallery
I'd be interested to find out if it was plug n play wiring harness too! I hate to spend $200+ to get a camera to work with my nav unit as you can purchase inexpensive wireless units for less than $80 w/monitor... Just sayin.
Sign Guy is offline   Reply With Quote
