09 Hybrid HID ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2008, 06:11 AM   #1 (permalink)
View George350's Photo Gallery
09 Hybrid HID ?
I'm a brand new owner of a hybrid... Had a 08 Nissan Rogue and traded it for the Camry in 3 months...
Only mod I have done is Tints... Now I want to get HID's.. I looked and there are so many out there, and I want to know whats a good brand to go with and if you have HID's where did you buy it from?
George350 is offline   Reply With Quote
Old 07-09-2008, 10:11 AM   #2 (permalink)
View mikeycj's Photo Gallery
Canada Tch 2009 Hid??
Nice car. I just purchased my TCH09 two weeks ago. Still waiting on delivery. I also want to put in HID lights, but I was wondering if it would affect the battery more than the standard lights. Anyone know?
mikeycj is offline   Reply With Quote
Old 07-15-2008, 10:33 AM   #3 (permalink)
View DRod's Photo Gallery
HID's on TCH
http://www.toyotanation.com/forum/t149337.html
DRod is offline   Reply With Quote
Old 07-20-2008, 07:08 PM   #4 (permalink)
tharvey's Avatar
View tharvey's Photo Gallery
I have done 2 conversions for a 2009 hybrid. I used an all electronic/digital slim series conversion kit from ebay.
It was $140 shipped and they worked perfectley once you know the wires are reversed polarity and to bend the connections inwards in order to get the connections to seat the first time.
On the drivers side I double sticked the 1/2" thick ballast to the abs controller and on the drivers side I double sticked the ballast to the rear of the electronic module.
All the wiring neatly hides away and it is basically plug and play and looks great.
I went with the black digital ballast as they do not have the enormous start up draw that conventional ballasts do.
Normally the HID's run at about 35 watts as compared to the conventional 65 or 60 watt halogen bulbs, so it appears that they are lower power consumption then halogen.
However the ballasts have a start up draw of about 200 watts for 5-15 seconds thus on some vehicles overloading the wiring and this is why some hid kits come with a relay kit to allow fro the tremendous start up draw.
These digital units compensate for this electronically and thus no extra relay kit is necessary, I have confirmed this on my amp meter and see virtually no additional start up load with these kits.
As for your original question the halogen run at 65 watts or 4.42 amps at 14.7 volts which is what my camry is putting out.
The hid kits run at 35 watts or 2.3 amps at the same 14.7 volts.
So you can see the hid's will not only give you better and cleaner light but also do it for about only 52% of the power needed to run the halogen bulbs.
I have hid conversions for about 5-6 years on various vehicles and have only seen them to get better and cheaper, my first set was over $1,000, now I am paying $140 for digital ultra slim units which are better quality and smaller then ever before.
Personally for $140 they are cheap insurance, I stay with the 4300K or 5000K light output.
hope this helps you out
tim
tharvey is offline   Reply With Quote
Old 08-02-2008, 11:57 AM   #5 (permalink)
View kirklandhybrid's Photo Gallery
seller on ebay?
Do you remember who the seller was on ebay? Also, what size bulb is on the '09 TCH? Thx! PS Anyone added fog lights? I'm interested in doing....
kirklandhybrid is offline   Reply With Quote
Old 08-02-2008, 12:59 PM   #6 (permalink)
tharvey's Avatar
Canada
Here is where I got mine
http://cgi.ebay.com/ebaymotors/ws/eB...m=190225044695
you have to ask for black and also ask for the double stick mounting method otherwise you will get silver ballasts and brackets and screws for the mounting.
I used the 5000K bulbs, the 4300 k might have also worked.
Tim
Old 08-02-2008, 01:06 PM   #7 (permalink)
tharvey's Avatar
I believe the bulb is H11 but you can check your owners manual and also specify the make/model/year in your order.
Remember to reverse the 18" connector as this cable is reversed in polarity, otherwise it is plug and play.
Tim
Old 08-03-2008, 08:05 PM   #8 (permalink)
one more question
Thx for the link.....will buy a pair once I determine the proper bulb size. How did you learn about reversing the 18" connector? Did it concern you that such a critical piece was not manufactured correctly? I'm assuming if you didn't reverse the connector you'd short the thing out?
Thx
Old 08-03-2008, 08:36 PM   #9 (permalink)
tharvey's Avatar
first install I found out the hard way over 2 hours to figure such a simple mistake, no damage to ballasts whatsoever
now I use a meter to verify regardless of what it states.
didn't really bother me as different auto manaf. use different sides for polarity, best always to check first.
all in all I have done 4 of these kits and they work well and the service was excellent, had it in 2 days once for an auto show and all at the same price.
Old 08-05-2008, 04:25 PM   #10 (permalink)
? for tharvey
so I have bought the HIDs and looked at the engine compartment last night...and with the 12v battery in the trunk, how exactly did you wire it back there? appreciate your help as always...thx much!
Old 08-10-2008, 01:02 AM   #11 (permalink)
Hybrid Owner
Intrus101's Avatar
View Intrus101's Photo Gallery
I was actually going to start making these to help people... Is it something that people would buy?
It's a direct plug in for the TCH low beams
Intrus101 is offline   Reply With Quote
Old 08-10-2008, 09:27 AM   #12 (permalink)
what is it?
Old 08-10-2008, 10:16 AM   #13 (permalink)
Hybrid Owner
Intrus101's Avatar
It's a pigtail. Plug-and-play harness for the Camry. It works with any Digital HID Ballast.
Just plug one end into the stock H11 plug (Where the low beam normally plugs in) and the other end plugs into the Ballast. If you are using a Digital Ballast, you do not need to run any extra wire or relays.
Old 09-10-2008, 04:33 PM   #14 (permalink)
View MysticX23's Photo Gallery
Sorry for asking, but I'm a car newb. Does the connection go like:
HID bulb -> ballast -> 12v in the trunk
or
HID bulb -> ballast -> original connector for normal bulb?
Looks hard if you have to connect wire it to the trunk.
MysticX23 is offline   Reply With Quote
Old 09-10-2008, 04:36 PM   #15 (permalink)
Hybrid Owner
Intrus101's Avatar
that depends on your ballast. A 35W Digital can be plugged directly into the original H11 socket.
A non-digital ballast needs to be powered by the battery, as the turn-on draw is higher than the 65W that the stock wiring is rated for.
Dave Joyce
2009 Camry Hybrid
My 2009 TCH
Lighting Upgrades
