Paint removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2008, 12:56 PM   #1 (permalink)
View pattieman's Photo Gallery
Paint removal
Have a 09 TCH, and I must to gone thru some paint (Silver) cars black and splashed some on rocker panel behind wheel wells on left side. Some one suggestted wet sanding or Quixx, any good recommendations, Pattieman
pattieman is offline   Reply With Quote
Old 08-02-2008, 01:11 PM   #2 (permalink)
tharvey's Avatar
View tharvey's Photo Gallery
I have had this happen a couple of time and I use a good cleaner/wax very gently and it all came off.
I used simonoz cleaner/wax for the lighter stuff and TR3 for the more stubborn paint.
tharvey is offline   Reply With Quote
Old 08-02-2008, 01:16 PM   #3 (permalink)
View toyomoho's Photo Gallery
Don't sand unless you have, see if the cleaner/wax does the job.
Always start out with the most mild stuff you can, you can always work up.
Old 08-02-2008, 01:17 PM   #4 (permalink)
Gameroom cash: $197815
View Frodo65's Photo Gallery
Kinda depends on what kind of paint you went through.
For Latex, Goof-off will do a decent job; just make sure you wax the areas afterward, and don't go overboard. Magic Eraser will work on fenderwells, but I wouldn't recommend it for the shiny areas, as it's abrasive. Cleaner/waxes or dedicated cleaners or clay treatments may also help. Also, the longer the stuff stays on, the harder it will be to remove.
Frodo65 is offline   Reply With Quote
Old 08-02-2008, 01:52 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $612031
View Zembonez's Photo Gallery
Acrylic enamel reducer will take off stubborn paint if you are careful. Use it sparingly and only for short periods at a time or it will soften up the paint you want to keep too. I used it to get off yellow road striping paint that was dry and hard. It took a little patience but it worked and you can't tell it was ever there.
Zembonez is offline   Reply With Quote
Old 08-13-2008, 10:40 PM   #6 (permalink)
View fraw's Photo Gallery
I am just applying wet sanding if my car got a very deep scratch then that's the only time I'm going to use that Quixx stuff which is actually good for scratch removal.
___________________________________
Car racing is not just all about speed, skill drives along with it,
fraw is offline   Reply With Quote
Old 08-14-2008, 03:17 AM   #7 (permalink)
paint removal
Thanks guys , used some kerosene with a little elbowgrease and it came off. Then waxed it with some Zaino, came out great. Last week clayed car and it came out like glass with Mothers clay bar and some cleaner wax.
