Disable TC
Winter is at our door and last year had a few times that I could have used a way to temp, disable the traction control. I know that the other models can disable by doing a sequence of steps. (Parking brake on to start 2-press brake twice 3- pump parking brake 2 times--tc disabled until restart.
This is not working for the hybrid. Any ideas?
Also tried
1. Make sure the car is in Park and the parking brake is disengaged before you start the car.
2. Start the engine.
3. Engage the parking brake.
4. Fully depress the brake pedal and then release.
5. Fully depress the brake pedal and then release.
6. Disengage the parking brake.
7. Fully depress and hold down the brake pedal.
8. Engage the parking brake, then disengage it(while holding down the brake pedal).
9. Engage the parking brake, then disengage it(while holding down the brake pedal).
10. Release the brake pedal.
11. Engage the parking brake.
12. Fully depress the brake pedal and then release.
13. Fully depress the brake pedal and then release
No luck
