THC Quirk??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2008, 02:26 PM   #1 (permalink)
View Old-Crows's Photo Gallery
Question TCH Quirk???
After coming to a stop, I hold light pressure on the brake to keep the car from moving forward. Occasionally I've noticed that the "monitor thingie" is showing an arrow from the battery to the 'wheel.' Apparently its indicating that the motor generators are being energized. Pressing harder on the brake makes the arrow disappear.
I think this is somewhat like putting your foot on the gas and holding the brake on in a conventional car.....
Must I hold a heavy pressure on the brake to avoid burning something out?? Obviously I'm using current out of the battery when its working like this.
Or, is it OkeyDokey to hold just enough brake pressure to keep the car from moving forward???
Should I put it in neutral? Yes, I know the battery won't charge in "N"....
Any thoughts???
O-C
Old-Crows is offline   Reply With Quote
Old 10-24-2008, 07:57 PM   #2 (permalink)
tharvey's Avatar
View tharvey's Photo Gallery
Canada
I have noticed the same thing.
When I come to a stop it still shows consumption until I apply the brake pedal harder.
I was thinking it was a pedal calibration issue where the vehicle thinks that it has not yet received a full brake application.
tim
tharvey is offline   Reply With Quote
Old 10-25-2008, 01:25 AM   #3 (permalink)
TMS Prius Expert
Tideland Prius's Avatar
View Tideland Prius's Photo Gallery
Same thing with an automatic.... the engine is still trying to move the car forward but there's nothing to tell you that the engine is powering the wheels.
It's the same for all Toyota hybrids. Firm on the brakes!
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
Tideland Prius is offline   Reply With Quote
Old 10-25-2008, 09:14 AM   #4 (permalink)
Thanks, Tim & Tideland
Do either of you suppose that its a big problem to not be firm on the brakes?? It is sort of like an automatic in Drive. Even then, I don't put heavy pressure to hold the car... just enough, only.
T-C
Old 10-25-2008, 12:20 PM   #5 (permalink)
TMS Prius Expert
No but why put unnecessary stress on the system right? My dad does that and all I can see is that the battery loses charge slowly (depending on the light, he can go from 6 bars to 5). To me, that's a waste of charge cause that can be used for actual propulsion of the vehicle.
Old 10-25-2008, 02:03 PM   #6 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
T-C
As an owner of both the Prius and the TCH, I'm with Tideland on this (if not his car color selection ). Depress the brake hard enough to eliminate the draw on the traction battery. There's no reason at all to allow the thing to discharge, unless it's either for propulsion or AC power. Other than that, it's a waste of power.
2009 Camry Hybrid, Black.
2007 Avalon XLS, Cassis Pearl (that Burgundy color).
2004 Prius Package 9, Black.
ekpolk is offline   Reply With Quote
Old 10-26-2008, 05:28 PM   #7 (permalink)
Thanks Guys!!! I agree on all points.
I'm going to have to work on my brake technique....
O-C
Old 10-26-2008, 05:54 PM   #8 (permalink)
TMS Prius Expert
np.
Old 10-28-2008, 09:23 AM   #9 (permalink)
View hoser's Photo Gallery
I tried your break test and found mine is the same. I never have the consumption screen on so this was a surprise. Thanks for posting. Surprising how firm you need to hold at a stop.
hoser is offline   Reply With Quote
Old 10-28-2008, 09:32 AM   #10 (permalink)
Cool
Well, just to add fuel to the fire.......
Yesterday, I noticed that you can have both the ICE and MGs engaged with only a light touch on the brake. Pressing harder on the brake shuts down both.
Honestly, having to hold hard pressure on the brake is a pain.
I'm thinking of shifting to "N" while stopped at a light.
O-C
Old 10-28-2008, 07:11 PM   #11 (permalink)
TMS Prius Expert
hehehehe. You think that's hard.... the smart's brake pedal has even more resistance.. ugh.
Old 10-28-2008, 10:21 PM   #12 (permalink)
The Regenerator
ekpolk's Avatar
Uh-oh. Please look carefully at the title of your thread. Yes, indeed, THC does have a lot of quirks -- including the notable ability to cause one to fail drug tests. I do find the TCH to be intoxicating as well, but in a much more legal and socially acceptable way. . .
Old 10-29-2008, 10:43 AM   #13 (permalink)
Thumbs up
Legal and drug free! I guess that "Excellent" econ rating and seeing 38+ mpg on the clock accounts for that giddy feeling every time you drive it. And here I was thinking it was the 'new car' smell!!!!
Seriously, it does put a smile on your face!!!
O-C
Old 10-31-2008, 02:53 PM   #14 (permalink)
Smile More Quirk!!!!
Ahhh Haaa!!!! Now this is interesting...
Holding a 'light' brake pedal while stopped and then shifting to Neutral (N) kills the energy drain from the battery to the traction motor.
WITHOUT changing brake pressure and shifting back to Drive (D) the traction system stays OFF and re-engages when you touch the gas pedal.
And..... contrary to what has been said about the battery not being charged when in Neutral (N).... the ICE will engage and charge the battery.
Cheers,
O-C
Old 11-01-2008, 05:00 PM   #15 (permalink)
TMS Prius Expert
Really? I've had the engine running in N but nothing showing on the MFD. Now I don't have a scangauge to see if the battery is charging but my screen shows no arrows with the engine running in N.
Edit: Also if you're in N and the engine is off and the battery drains to two bars, it will not charge. I have had it drop to one bar before while waiting at the border cause there's a slight downhill at one point so to conserve battery, I leave it in N and let it roll down rather than in D and having the battery power the car.
