You'll need a 3.5mm male-male audio connector to make the connection between your iPhone and the car. The auxiliary input jack is located in the bin below the climate controls, next to the 12V. It's quite deep so you're gonna have to reach quite far in to find it. Once you connect the wire, just leave it connected to the car and unplug it from the iPhone. Conveniently, Toyota has also added a side port so that you can leave the iPhone on the right cubby hole and have it wired into the jack from the side. It's the square-ish looking cutout when you look from the passenger side.
This method does not allow control of the iPod via the car's radio controls. You'll have to control it via your iPhone (e.g. changing tracks)
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
