07 Camry Hybrid remote key battery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2009, 01:58 PM   #1 (permalink)
View dannw1431's Photo Gallery
Hello, one of my remote keys for my 07 Hybrid Camry has a battery problem. When I get in the car the display reads low battery. Do I have to go back to the dealer and have them replace the battery in the remote key, or is there another place I can go and have this done?
thanks
dannw1431 is offline   Reply With Quote
Old 04-21-2009, 03:43 PM   #2 (permalink)
View keithet's Photo Gallery
Talking How to Replace 2007 battery in FOB
No need for dealer interface. Mine is a 2007 and complained today that it needed replacing!.
1. Take key out of FOB
2. Use a small flat blade screwdriver to separate the case (pry at slot near the key hole).
3. have a new 1632 battery ready.
4. lift circuit board out of shell and turn over.
5. Remove dead or weak 1632 and replace the same way with new 1632.
6. Put the two halves back together and snap them to close.
7. Reinsert key.
8. DONE! Faster than I took to write this!!
It's also explained in manual on about page 29 I believe!
keithet is offline   Reply With Quote
Old 04-21-2009, 04:27 PM   #3 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
To add to the above: Instead of using a flathead screwdriver, simply use the end of the mechanical key. The end of the key fits the hole perfectly.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 04-21-2009, 05:55 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
You mean all the words in the Owners Manual are there for something??
Old 04-27-2009, 05:07 PM   #5 (permalink)
Hi and Thanks for the advise. I took about a minute to install the new batery and the remost key is working great.
Old 08-11-2009, 06:01 PM   #6 (permalink)
View astrokat's Photo Gallery
Thanks for this info BTW - it has also helped me.
astrokat is offline   Reply With Quote
Old 03-20-2010, 03:16 PM   #7 (permalink)
View stuarta's Photo Gallery
key battery low camry hybrid
I have a 2007 Camry Hybrid. No tools required to remove battery. Remove the backup key from the electronic key. It inserts into the slot on the bottom of the electronic key box. You don't need a screwdriver to open it. It's designed for that. Thanks for the info. I looked inside, and didn't realize the battery was on the other side of the circuit board.
stuarta is offline   Reply With Quote
Old 03-20-2010, 06:26 PM   #8 (permalink)
View Pipemajor's Photo Gallery
I had ours in for service a few months ago and brought both keys in for them to look at after getting a "low battery" indication on mine and a "no remote key detected" on hers. They replaced the batteries in both keys for me - no charge. Both are working just fine now.
'10 TCH, Magnetic Grey Metallic, Moonroof, Heated Leather and NAV
'92 LE I4, 165k original miles, Silver Taupe Metallic, Moonroof, ABS
Pipemajor is offline   Reply With Quote
Old 01-27-2011, 02:57 PM   #9 (permalink)
Registered Gator
View GvilleTCH's Photo Gallery
TTT , with 85,000 miles and 2 1/2 years of use , I power off my TCH and I too received the "low key battery" message. After replacing the battery , the message is gone and all is back to normal. Thanks for this info as it was quite handy , so I bring it to the top for current viewing...
2009 BRM/Bisque TCH : UT w/Nav,LA,SR,CQ with PV50 and RX60. CoverCraft Evolution and UVS100; FormulaOne Pinnacle 35/15/15 Tint; LLumar Paint Protection; Vinguard; Mudguards; Silverstar Ultra 9005 & Silverstar 3457A. AMSOIL SS 0w-20 w/ EaO10 ; Shell V-POWER 93
GvilleTCH is offline   Reply With Quote
Old 05-03-2011, 10:42 AM   #10 (permalink)
View spearjb1342's Photo Gallery
Low key battery
I have an 07 TCH. 4 out of 10 times after shutting my car off I get the "low key battery" message. I've had the batteries tested are they are fine. Any suggestions?
spearjb1342 is offline   Reply With Quote
Old 05-06-2011, 02:39 PM   #11 (permalink)
View andym1978's Photo Gallery
The 12v and highvoltage battery will not cause that message. You need to replace the watch battery in your key FOB. If you were referring to the key fob battery when you mentioned testing, replace it anyways. The key fob will complain even if the battery tests "good" in a battery tester. Mine lasted 3 years before getting too low. If your is still original from 2007, then you 100% need a new one (and get a new one for the spare as well). Get the Panasonic ones from Amazon. Those are the same as OEM and work great. The battery and shipping should be under $10, so don't pay more.
andym1978 is offline   Reply With Quote
The Following User Says Thank You to andym1978 For This Useful Post:
spearjb1342 (05-07-2011)
Old 12-04-2011, 04:50 PM   #12 (permalink)
View CamryHYBRID_07's Photo Gallery
Wink CR1632 Battery
I just replaced my 2 remote car key battery with NEXXTECH CR1632 LITHIUM COIN CELL BATTERY . Bought it from The Source here in Canada for $6.49 each.
Got it done and is now working fine.
Thanks for this info... that was easy :-)
CamryHYBRID_07 is offline   Reply With Quote
Old 12-09-2011, 03:36 PM   #13 (permalink)
Buyer's remorse
View razol's Photo Gallery
Even better, you can get the five of the batteries that you need for less than the previous poster paid for one. Just go to Amazon:
Amazon Amazon
$ 5.41
--or get them with free shipping for $6.99 if you are a Prime member:
Amazon Amazon
These are good to have around as you never know when you will need one, and paying $6 for one is a bit much for me.
razol is offline   Reply With Quote
