2007 TCH-Bad engine pinging - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2009, 10:07 AM   #1 (permalink)
View rickmag's Photo Gallery
About six months ago, I started hearing pinging upon light acceleration at between 20 and 30 MPH. Pinging varies from light to very bad and is worse when under light or moderate load/incline and when weather is warm. Pinging has occurred across many tanks of gas of different brands---top-tier and non-top-tier.
Dealer (Magnussen Toyota, Palo Alto, CA) was dismissive but did say that the issue is coming up more frequently with TCH's. They advised higher octane gas (not the right answer).
Anyone else out there with this problem?
rickmag is offline   Reply With Quote
Old 09-13-2009, 07:01 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
In the following order as necessary:
1. Run some injector cleaner through for a couple gas tanks ;
2. Disconnect the battery for a couple minutes and let the ECU reset;
3. Seafoam to remove combustion chamber deposits that increase the compression ratio.
Old 09-14-2009, 04:09 PM   #3 (permalink)
View jsseibel's Photo Gallery
Interesting... you know this engine doesn't have traditional pistons, etc? I'm curious as to why you'd get "pinging?" This is basically a rotary engine.
jsseibel is offline   Reply With Quote
Old 09-14-2009, 06:38 PM   #4 (permalink)
View Pipemajor's Photo Gallery
I'm sure the 2.4l 2AZ-FXE engine used in the Camry Hybrid is basically a reciprocating 4 cylinder engine, not a rotary.
from Wikipedia:
The 2AZ-FXE is a variant of the 2AZ-FE. It has the same bore and stroke, but has a higher physical compression ratio of 12.5:1. The net result is that the engine has a greater effective expansion than compression – making it Atkinson cycle, rather than the conventional Otto cycle.
The reduction in cylinder charge means reduced torque and power output, but efficiency is increased. This combination makes the 2AZ-FXE suitable for use in hybrid vehicles, where peak torque and power demands can be met by the electric motor and battery.
Maximum output when used in the Camry is 147 hp (108 kW) at 6000 rpm with 138 ft·lbf (187 N·m) of torque at 4400 rpm.
'10 TCH, Magnetic Grey Metallic, Moonroof, Heated Leather and NAV
'92 LE I4, 165k original miles, Silver Taupe Metallic, Moonroof, ABS
Pipemajor is offline   Reply With Quote
Old 09-14-2009, 09:03 PM   #5 (permalink)
'07 XLE
Gen6
What elementary school are you enrolled in????
Old 09-14-2009, 09:50 PM   #6 (permalink)
View Axxis8203's Photo Gallery
lol, couldn't have put it more succinctly njerald
the manual states these engines should run on 87 octane, there's no way in hell i'd let the stealer tell me to buy premium. we're talkin a camry here, not an IS-F.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 09-15-2009, 06:47 PM   #7 (permalink)
LCromwell's Avatar
View LCromwell's Photo Gallery
The proper way to put Seafoam thru, is to find a vacuum hose and have the engine suck it up into the intake manifold until the engine dies and then let it sit for at least 15 minutes. Then start it and run the hell out of it while it will be blowing white heavy heavy smoke all over the place. This is what I do with my Lincoln Mark VIII, I go out of Town and pull off the side of the road and then when it is done and 15 minutes has elapsed run it like hell down the highway.
The Bitterness of Poor Quality,Lingers Long After the Cheapness of Price is Forgotten!
LCromwell is offline   Reply With Quote
Old 12-23-2009, 06:22 AM   #8 (permalink)
TCH 2007 newbie May 07
View Ed_T's Photo Gallery
Pinging cured
07 Camry Hybrid:
I had the pinging using 87 octane happen about a year+1/2 ago during warm months, under same low-speed conditions.
I switched to running the car on 89 for a year. Then last summer, I switched back to using 87 octane. No more pinging. Same great fuel efficiency.
Occasionally I would make (fully warmed engine) a hard acceleration run on the highway. I think this teaches the e-brain what the timing advance limits are.
I am not sure why the hot weather pinging stopped, but it did.
Ed_T is offline   Reply With Quote
Old 12-23-2009, 11:31 PM   #9 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
OK, a little less crack -- a little more knowledge. That formula would serve you well before posting.
The 2AZ-FXE is not "basically a rotary" at all. It's very similar to its sibling, the 2AZ-FE, but "re-rigged" to run in Atkinson cycle mode, when appropriate. Open a TCH hood and have a look for yourself.
OK, back on topic. My TCH is an 09 and now has 42,000 miles. I'm sensitive about pinging (I hate pinging...), and I have not been able to induce this car to ping, AT ALL. I run 87 octane fuel, almost always Top Tier spec fuel (Shell, Texaco, etc.). I do also spike my fuel with synthetic TCW-3 2-stroke oil at about 400:1. The TCW-3 probably has nothing to do with my non-pinging, but I do seem to get slightly better mileage with it (questionable whether the stuff would pay for itself, but I like experimenting).
2009 Camry Hybrid, Black.
2007 Avalon XLS, Cassis Pearl (that Burgundy color).
2004 Prius Package 9, Black.
ekpolk is offline   Reply With Quote
