Originally Posted by Droid13
Yes, perfectly normal. If you enjoy driving on battery power only, you've probably figured it's easier in summer than winter. Having the climate system in ECO will help, off altogether is best. Accelerate moderately briskly to 60kph and release gas pedal. Re-apply gently to try to maintain speed. For some reason its far more likely to slip into E than if you only accelerate to 40kph.
The maximum "stealth" (electric only drive) speed is 42 mph (although per my ScanGauge-II, mine seems to max out at 37-38 mph, NOT kph). This is an inherent design feature in the HSD cars. It results because of the gearing of the PSD (essentially the core of the tranmission). If the car were permitted to go "stealth" over 42 mph, it would result in an over-revving of MG1 (the smaller of the two motor-generators, driving the centershaft of the PSD).
Go to the link below to see a very neat, interactive depiction of how the parts of the PSD work with one another. Go half-way down the page. You can move those sliders with your mouse. Slowly slide the left-most one (representing MG2 rpm) upward, and watch the speedometer. As you hit 42 mph, you'll see you reach max rpm for MG1.
http://eahart.com/prius/psd/
As for the climate control, other than turning the AC compressor off in cold weather, I'd leave it on. I do realize that you're in Canada, Driod, so your climate is very different from mine, where combating HEAT is the main climate challenge. Remember, the traction battery is cooled by "used" cabin air. The battery cooling intake is that large vent scoop on the shelf behind the rear seat. In the Prius, it's a vertical affair at the right rear passenger's outboard shoulder. Anyway, if you try to save gas in hot weather by shutting off the climate control, you may deprive the traction battery of sufficient cool air. If you do so, the computers will scale back the "involvement" of the traction battery, reducing the system's overall efficiency, and ultimately lowering your mileage.
Back to the OP's question, yes, what you describe is normal (unless you're getting system warnings, which you did not indicate). Having owned and driven both the Prius and the TCH, I find that the Prius is much easier to "maneuver" into stealth mode, and much easier to keep it there. The TCH strikes more of a compromise between performance and economy, and seems to be programmed to start the ICE much more willingly than the Prius which is clearly programmed more heavily in favor of fuel economy. Be subtle, steady and gentle with the TCH's throttle, and you'll get the hang of milking it along in stealth mode. A good specific technique is to accelerate to a couple mph/kph ABOVE your intended speed, and then "back down" to that. That gets me into stealth very frequently and easily.
Finally, don't get overly frustrated with it. The computer weighs many variables, most of which you can't directly see when deciding whether or not to go stealth(hint: get a ScanGauge...). If coolant temp is too low, for example, even if you do everything right, the ECU will keep the ICE running. And so on.
