air sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2010, 09:30 PM   #1 (permalink)
View jfount's Photo Gallery
Unhappy air sound
2007 Camry Hybrdi. (I love it!)
I was hit on the driver's side ($14,000) worth of damage. Everything from the trunk to the front fender was put back so it looks perfect. I now have air noise coming from inside the door. (no leaks inside the car, just the noise) Mostly from the outside mirror area. I have had dealers look at it and they say it looks right. The air sound is driving me crazy...Any help out there?
Is the hybrid sound deadening different that the standard camry?
jfount is offline   Reply With Quote
Old 01-30-2010, 09:39 PM   #2 (permalink)
View Timm099's Photo Gallery
Try your best to pin point it and call the body shop that did the work and ask them to look at it. you might be able to find it better by spraying it with a water hose and looking for water leaks. Hope this helps
Timm099 is offline   Reply With Quote
Old 01-31-2010, 08:15 AM   #3 (permalink)
View ancistrus's Photo Gallery
Not sure if the sound deadening in the side is any different. The TCH does, however, have a special low-noise-transmission windshield.
ancistrus is offline   Reply With Quote
Old 01-31-2010, 10:12 AM   #4 (permalink)
Thanks for the suggestions, the body shop has had it 5 times they say they ahve adjusted everything. But I'm unsure if the Hybrid is differnt. They work off the standard camry illustrations.
The water might work if it was actualy coming in the car, it sounds like its in the door and the noise only is coming in
