Hybrid rear brake wear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2010, 04:48 PM   #1 (permalink)
View heathholley's Photo Gallery
USA Hybrid rear brake wear
Hi everyone,
So I'm curious about something and was hoping for another person's opinion. I recently took my 2007 TCH in for it's 50k mile service. I purchased the car March 19, 2006 brand new. Since then, I have (religiously) taken my car to the dealer for every 5k mile service. Last week, my dealer informed me that the rear brake pads were down to 2mm and needed to be replaced. Curious about my brake pad usage over the past 50k miles, I pulled out my service receipts which list the thickness at each inspection.
I plugged the data into a spreadsheet and used it to create the graph below.
So, my question is this. Why isn't my brake wear (for front and back) in a straight linear motion downward? For example, how did I go from 7mm to 2mm in 5000 miles?? Or better yet, how did I go from 5.5mm to 8mm in 5000 miles? Are these magic Toyota brake pads that sometimes regenerate themselves?
Please, someone, enlighten me.
heathholley is offline   Reply With Quote
Old 02-12-2010, 05:10 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
There are 4 pads/axle.
They could be measuring different pads, measuring them wrong or lazy and just guessing.
Nothing tough about that.............
Old 02-12-2010, 05:17 PM   #3 (permalink)
True. I suppose I expected a more accurate inspection from the dealership. If they are in fact lazy/guessing or just wrong, maybe I should just take it to Jiffy Lube (or the like) for service instead.
Old 03-12-2010, 05:34 AM   #4 (permalink)
View jim2527's Photo Gallery
Heat will expand the pads...they 'grow'. If they're measure while hot they can be a different size. I think wear is exponential, as they wear there's less material to dissipate heat, less heat disspipation leads to an increase in wear.
An ohhhh.....the mechanic was probably saying, "WTF, is this guy insane" and eyeballed the measurement.
jim2527 is offline   Reply With Quote
Old 11-11-2010, 11:00 AM   #5 (permalink)
2007 Camry Hybrid
View acarapella's Photo Gallery
Remeber... The TCH uses the drivetrain for breaking upfront, saving the pads. The car is not awd, thus the rear wheels need to use the breaks... So they wear faster. Same thing with mine. Replaced all the way around at 59,000 miles
2008 Camry Hybrid NAV - Barcelona Red (Current)
2006 Solara SLE V6 Nav - Silver (Current)
2008 Lexus IS250 Premium - Gray - Sold
2007 Camry Hybrid - Barcelona Red - Sold
2009 Corolla "S" Eibach Pro - White - Sold
1992 Corolla - Blue - Sold
1999 Camry XLE Special Edition - White/Silver - Sold
acarapella is offline   Reply With Quote
Old 11-13-2010, 04:49 PM   #6 (permalink)
ukrkoz's Avatar
Gameroom cash: $189750
View ukrkoz's Photo Gallery
every front wheel drive car brakes down more with front wheel brakes. period, end of sentence. no matter how well proportionate valve is working, it's the weight distribution.
i have replaced dozens of brake pads, on various domestics and imports, and front always needs to be replaced first, waaaaaay ahead of rear.
btw, i have just checked mine today, same model. they are only 1/4 worn out. 52 000 miles. wear is more or less equal per rotor sides, but caliper guides already lost lubricant on them and were not sliding well. fixed that.
as of all those measurements - looks like quite a yarn your dealer is weaving for you. bs, otherwise.
ukrkoz is offline   Reply With Quote
Old 12-03-2010, 06:43 PM   #7 (permalink)
View Duramax2002's Photo Gallery
My 2007 hybrid has over 140k miles changed rear pads first at 86k. The front pads were not changed until almost 100k. Have changed the rear again since and not the front. The back wear almost 2 to 1. I know this goes against normal convention???
Duramax2002 is offline   Reply With Quote
Old 12-20-2010, 06:04 PM   #8 (permalink)
Gameroom cash: $197815
View Frodo65's Photo Gallery
The TCH is different in that regard. For light braking, the fronts don't get much use; it's the rears + the MG 1 / MG2 spooling up. Only if you REALLY stomp on the brakes (or below 5 MPH or so) that the fronts get a workout. A IR thermometer will confirm - it's the first FWD car where the rear brakes have higher running temps than fronts.
Frodo65 is offline   Reply With Quote
