Brake Wear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2010, 07:20 AM   #1 (permalink)
VMAN2644's Avatar
View VMAN2644's Photo Gallery
Brake Wear
I have 2007 Camry hybrid with 58,000 miles on it. Brakes still good Can anyone give me some idea when they replaced brakes front or rear I am told rears go first. Has anyone tried the aftermarket slotted and drilled rotor pad combination. Thanks
VMAN2644 is offline   Reply With Quote
Old 03-03-2010, 07:53 AM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Your brakes are still good yet you don't know the respective pad thicknesses? You should be able to answer your own question....
Old 03-04-2010, 08:10 AM   #3 (permalink)
Gameroom cash: $240090
View The7's Photo Gallery
It is understanding that the brake pads on TCH will last much longer than non-hybrid one because TCH uses electrical regenerative braking as well as normal hydraulic braking.
How many times will they last longer ?
The7 is offline   Reply With Quote
Old 03-07-2010, 06:05 PM   #4 (permalink)
View mobilest's Photo Gallery
I checked the pad thickness on the rear discs during a tire rotation and discovered that one pad was worn a lot more than the other, ( and the same for the other side ) so I switched them to even up the wear. Be aware that the I should have changed them from side to side to keep the wear indicators in the correct orientation, but since I rotate my own tires I can check them every 5k and it won't be an issue. If I was really on the ball I would have taken the caliper apart to see if it was lubed right. Something definitely is amiss since the pad wear was more than double on one side. I called my favorite service writer at my local Toyota dealer and told him about this problem and he wasn't aware of any other instances. But I put over 100 miles a day on my car ( an '07, 82k so far ) and I may be the Guinea Pig for this situation.
mobilest is offline   Reply With Quote
