2010 TCH Preliminary MPG Results
Tank #1 - 39.1 mpg
Tank #2 - 39.1 mpg
Tank #3 - 38.9 mpg
Total miles is about 1950, springtime weather between 30-65 degrees F. No AC use yet but definitely some cabin heat on EVO mode.
MID display routinely reports 41.x mpg numbers. Nice on the 2010 you can reset this when you want instead of only on a refueling stop.
Type of driving has been suburban (40%); rural (40%) and urban (20%).
Compared to our 2007 TCH, I still feel Toyota has tweaked the Synergy algorithms a bit since the powertrain is the same. I typically got between 36 and 38 mpg with the '07.
2007 TCH equipped with 215R60x16 Bridgestone Turanza EL400's on 16" alloys.
2010 TCH has 215R60x16 Michelin Energy MXV4's also on 16" alloys.
'10 TCH, Magnetic Grey Metallic, Moonroof, Heated Leather and NAV
'92 LE I4, 165k original miles, Silver Taupe Metallic, Moonroof, ABS
